Results 76 to 81 of 81
Thread: Which Tap & Die set to purchase?
1st Feb 2014, 11:55 PM #76
The dies with the slit in em ,make for adjustment of the cut thread.
Meaning you can make the cut male thread tighter or loose to custom fit the thread to the nut,within in a small range of course.
Yes are carbon steel but appear to be a good quality. I use the 6mm die on stainless rod all the time and its still cutting well after a year or so.
Here's some helpful stuff about dies
dies - ICS Cutting Tools
2nd Feb 2014, 02:45 AM #77
I've just recently bought a set of those from Aldi. The tapping size drills in that set are HSS and are split point. The taps seem to be HSS as well but don't have any indication on them, neither have the dies.
Other than that I've only used one tap from the set, M4 in BMS. It cut easily and left a clean, sharp in appearance thread. Having said that I would buy taps and dies as needed for repair work. Any new work I will stick to metric.Best Regards:
2nd Feb 2014, 07:57 AM #78Golden Member
- Jun 2004
- Kyabram. Vic
- 632
odd size threads
Geez Ewan, Ray Phil; you guys are just as warped as me.
I must be in good company.
Ken
2nd Feb 2014, 11:55 AM #79
I disagree....
Just sticking with the M8x1.25 for this calculation,
Drill Size = Basic Major Diameter of Thread - [% of full thread * Pitch] / 76.98 ..... ( Black Book page 22 )
So for a M8x1.25 60% ( loose fit ) Drill Size = 8.0 - [ 60 * 1.25] / 76.98 = 7.0 mm not the 7.2 mm quoted above.. 75% fit gives the standard drill size of 6.8 mm
Tubal Cains recommended drill size of 7.2mm gives only a 50%engagementflank.
Regardless of his errors, I'd dispute the assertion that tapping for a loose fit is a good way to stop breaking taps, starting square and not bending the tap seem to be more sensible approaches.
PS... On re-read I see that we might be swapping %flank height for %engagement when referring to fit? PC might be correct, this is getting a bit anal for home workshop applications...
2nd Feb 2014, 02:47 PM #80Member: Blue and white apron brigade
Yep - that's what is happening - the BB and TC equations are the same if the same parameters are being used.
Warning - NERD alert!
These equations come from the ISO specification for the metric thread (see ISO metric screw thread - Wikipedia, the free encyclopedia)
A 100% contact has the equation Drill size = Diameter of bolt - 1.082532*Pitch
A less than 100% contact, Diameter of bolt - 1.083*Pitch * % flank height/100
End NERD alert
Here is the TC chart I use - only a range of tapping drill sizes for the coarser threads are provided but any others can be worked out from the equation provided.
2nd Feb 2014, 07:36 PM #81
runout
Hi
A theory : If your spindle or chuck ( therefore drill shank )has any amount of runout, then the drill chart figures would not mean anything ?
It may be worthwhile measuring your drilled hole to see if it is actually the size you are wanting ... the smaller sizes may need one of those expanding ball devices ( small hole gauges ).
Mike
