Results 16 to 30 of 37
Thread: VFD Settings Huanyang HY01D523B
26th Jan 2014, 03:17 PM #16Novice
- Sep 2013
- melb
- 16
26th Jan 2014, 04:00 PM #17
Ok, this is getting strange, what are the decelleration times set to, PD15, PD17, PD19, PD21
26th Jan 2014, 07:45 PM #18Novice
- Sep 2013
- melb
- 16
26th Jan 2014, 07:53 PM #19Most Valued Member
Thats strange. Min setting on mine is 0.1.
Try setting them all to 5.
26th Jan 2014, 08:20 PM #20Novice
- Sep 2013
- melb
- 16
Stuart G'day,
Ok set all to 5, same difference.. going up good comming down not so good..
26th Jan 2014, 10:34 PM #21Most Valued Member
I'm starting to wonder if your VSD is fried.
If you'd like to make a list of all your PD settings I can compare them to the settings on mine, but I doubt we are going to find a magic number. I've been wrong before though.
26th Jan 2014, 11:28 PM #22Novice
- Sep 2013
- melb
- 16
Stuart G'day,
Ok sounds like a plan, I'll do that first thing in the morning.. almost midnight..
VSD fried who knows, but you made me go and smell it and it doesn't smell like its blown a gasket.
I'm sure it has to be something so dam simple..
Greatly appreciate your assist.
Cheers.
27th Jan 2014, 09:56 AM #23Novice
- Sep 2013
- melb
- 16
Stuart G'day,
As promised my settings.. I used a spreadsheet that I downloaded from this forum I believe and just filled out my numbers... cheers and again thank you for going to the trouble.
Code Function Set Range & Function Explanation Factory Setting PD000 Parameter Lock 0:Invalid 1:Valid 0 PD001 Source of Run Commands 0:Operator 1:External terminal 0 2:Communication port PD002 Source of Operating Frequency 0:Operator 1:External terminal 0 2:Communication port PD003 Main Frequency 0.00~400.00 Hz 400 PD004 Base Frequency 0.01~400.00 Hz 400 PD005 Max Operating Frequency 50.00~400.00 Hz 400 PD006 Intermediate Frequency 0.01~400.00 Hz 2.5 PD007 Min. Frequency 0.01~20.00 Hz 0.2 PD008 Max. Voltage 0.1V—* 220 PD009 Intermediate Voltage 0.1V—* 15 PD010 Min. Voltage 0.1~50.0V 8 PD011 Frequency Lower Limit 0.00~400.00 Hz 120 PD012 Reserved null PD013 Parameter Reset 00~10 08:Restore the factory setting. No other function. 0 PD014 Accel. Time 1 0.1~6500.0S 10 PD015 Decel. Time 1 0.1~6500.0S 10 PD016 Accel. Time 2 0.1~6500.0S 20 PD017 Decel. Time 2 0.1~6500.0S 20 PD018 Accel. Time 3 0.1~6500.0S 40 PD019 Decel. Time 3 0.1~6500.0S 40 PD020 Accel. Time 4 0.1~6500.0S 80 PD021 Decel. Time 4 0.1~6500.0S 80 PD022 Reserved 0 PD023 Rev. Rotation Select 0: Rev Run forbidden; 1:Rev Run Enable 0 PD024 STOP key select 0:STOP Invalid 1:STOP Valid 1 PD025 Starting Mode 0:Start from Starting Frequency 0 1:Frequency track start PD026 Stopping Mode 0:Decelerating stop 1 1:Coasting stop PD027 Starting Frequency 0.1~10.0 Hz 0.5 PD028 Stopping Frequency 0.1~10.0 Hz 0.5 PD031 DC Braking level 0.0~20.0% 2 PD029 DC Braking time at start 0.0~25.0S 0 PD030 DC Braking time at stop 0.0~25.0S 0 PD032 Frequency track time 0.0~20.0S 5 PD033 Current level for frequency track 0~200% 150 PD034 Voltage rise time during frequency track 0.5 PD035-PD040 Reserved null PD041 Carrier frequency 0~15 8 PD042 Jogging Frequency 0.00~400.00 Hz 5 PD043 S-Curve Time 0~6500S 0 *PD044 Multi-input 1(FOR) 0: Invalid; 1:Run; 2: For rotation; 3: Rev rotation; 4: Stop; 5: FOR/REV.; 6: Jog; 7: Jog For rotation; 8: Jog Rev Rotation; 9: Emergent stop; 10: Reset; 11:Reserved; 12: Overheat of heat sink or motor; 17: High speed; Middle speed; 19: Low speed; 20: Multi-speed 1; 21: Multi-speed 2; 22: Multi-speed 3; 23: Ramp select 1; 24: Ramp select 2; 25: UP function; 26: DOWN function; 27: Counter 28: Counter reset; 29: Drawing; 32: PID Start 2 *PD045 Multi-input 2(REV) 3 *PD046 Multi-input 3(RST) 4 *PD047 Multi-input 4(SPH) 7 *PD048 Multi-input 5(SPM) 19 *PD049 Multi-input 6(SPL) 20 *PD050 Multi-output 1(DRV) 0: Invalid; 1: Run; 2: Fault indication; 3: Zero Speed; 4: Braking indication; 5: Set Frequency reach; 6: Arbitrary Frequency 1 reach; 1 *PD051 Multi-output 2(UPF) 3 *PD052 Multi-output 3(Terminals of FA,FB,FC) 1 *PD053 Multi-output 4(Terminals of KA,KB) 7: Arbitrary Frequency 2 reach; 8: In Accel.; 9: In Decel.; 10: Inverter Overload alarm; 11: Motor Overload alarm; 12: Over-torque alarm; 13: Low voltage alarm; 14: Single stage end indication; 15: Process end indication; 16: Counter reach; 27: Drawing reach; 28:PID lower limit alarm; 29: PID upper limit alarm; 30: Fan act; 31: Reserved; 32: Braking resistor act 3 PD054 Multi-output 5(AM) Output of digital frequency signals 0 PD055 AM Analog output Gain 0.0~100.0% 100 PD056 Skip Frequency 1 0.00~400.00 Hz 0 PD057 Skip Frequency 2 0.00~400.00 Hz 0 PD058 Skip Frequency 3 0.00~400.00 Hz 0 PD059 Skip Frequency Range 0.00~2.00 Hz 0.5 PD060 Uniform Frequency 1 0.00~400.00 Hz 0 PD061 Uniform Frequency 2 0.00~400.00 Hz 0 PD062 Uniform Frequency Range 0.10~10.00 Hz 0.5 PD063 Timer 1 time 0~10.0 0.1 PD064 Timer 2 time 0~100 0.01 PD065 Counting value set 00~65500 0 PD066 Intermediate Counter 0~65500 0 PD067-PD069 Reserved PD070 Analog Input 0~10 0 PD071 Analog Filtering Constant 0~50 20 PD072 50 PD073 Bias Direction at Higher Frequency 0.00~400.00 Hz 0 PD074 0 PD075 0:Positive direction 1:Negative direction 0 PD076 Analog Negative Bias Reverse 0:Not allowable. 1:Allowable. 0 PD077 Up/Down Function 0:Not memorized 1:Memorized 0 PD078 Up/Down Speed 0:0.01HZ 1:0.1HZ 0 PD079 Reserved 0.01 PD080 PLC Operation 0:Normal run; 1: External control 4 -speed; 2:External control multi-speed; 3: Disturbance; 4: Internal control multi-speed; 5: Drawing 0 PD081 AutoPLC 0:Stop after running for one cycle; 1:Cycling run; 2:Auto stop after running for one cycle (STOP for intervention); 3: Auto Run and Cycling (STOP for intervention) 0 PD082 PLC rotation Direction 0~255 (0:For 1:Rev) 0 PD083 0~255 (0:For 1:Rev) PD084 PLC Ramp Time 0~65535 0 PD085 0~65535 PD086 Frequency 2 0.00-400.00 Hz 15 PD087 Frequency 3 0.00-400.00 Hz 20 PD088 Frequency 4 0.00-400.00 Hz 25 PD089 Frequency 5 0.00-400.00 Hz 30 PD090 Frequency 6 0.00-400.00 Hz 35 PD091 Frequency 7 0.00-400.00 Hz 40 PD092 Frequency 8 0.00-400.00 Hz 0.5 PD093 Frequency 9 0.00-400.00 Hz 10 PD094 Frequency 10 0.00-400.00 Hz 15 PD095 Frequency 11 0.00-400.00 Hz 20 PD096 Frequency 12 0.00-400.00 Hz 25 PD097 Frequency 13 0.00-400.00 Hz 30 PD098 Frequency 14 0.00-400.00 Hz 35 PD099 Frequency 15 0.00-400.00 Hz 40 PD100 Frequency 16 0.00-400.00 Hz 45 PD101 Timer 1 0.0-6500.0S 10 PD102 Timer 2 0.0-6500.0S 10 PD103 Timer 3 0.0-6500.0S 0 PD104 Timer 4 0.0-6500.0S 0 PD105 Timer 5 0.0-6500.0S 0 PD106 Timer 6 0.0-6500.0S 0 PD107 Timer 7 0.0-6500.0S 0 PD108 Timer 8 0.0-6500.0S 0 PD109 Timer 9* 0.0-6500.0S 0 PD110 Timer 10 0.0-6500.0S 0 PD111 Timer 11 0.0-6500.0S 0 PD112 Timer 12 0.0-6500.0S 0 PD113 Timer 13 0.0-6500.0S 0 PD114 Timer 14 0.0-6500.0S 0 PD115 Timer 15 0.0-6500.0S 0 PD116 Timer 16 0.0-6500.0S 0 Code Functions Set Range & Function Explanation Factory Setting PD117 AutoPLC Memory 0~1 0 PD118 Over-voltage Stall Prevention 0:Invalid 1:Valid 1 PD119 Stall Prevention Level at Accel. 150 PD120 Stall Prevention Level at Constant Speed 0~200% 0 PD121 Stall Prevention Level at Decel. 0~200% 5 PD122 0~200% NULL PD123 Over-torque Detect Mode 0~3 0 PD124 Over-torque Detect Level 0~200% 0 PD125 Over-torque Detect Time 0.1~20.0S 1 PD126 0 PD127-PD129 Reserved NULL PD130 Number of Auxiliary Pump 0~2 0 PD131 Continuous Operating Time of Aux. Pumps 1~9000mim 60 PD132 Interlocking Time of Aux. Pumps 1~250s 5s PD133 High Speed Running Time 1~250s 60s PD134 Low Speed Running Time 1~250s 60s PD135 Stopping Voltage Level 1~150% 95% PD136 Lasting Time of Stopping Voltage Level 1~250s 30s PD137 Wakeup Level 1~150% 80% PD138 Sleep Frequency 0.00~400.0 0 PD139 Lasting Time of Sleep Frequency 1~250s 20s PD140 Reserved NULL PD141 Rated Motor Voltage Set according to Motor nameplate 220 Set according to Motor nameplate PD142 Rated Motor Current 02—10 5 00—9999 PD143 Motor pole number. 2 PD144 Rated Motor Revolution 3000 PD145 Auto Torque Compensation 0.1—10.0 % 2.00% PD146 Motor no-load current 0—99 40 PD147 Motor slip compensation 0.0—10.0 20 PD148-PD149 Reserved PD153 Restart after Instantaneous Stop 0:Invalid 1:Frequency track 0 PD152 1 PD154 Allowable Power-Breakdown Time 0—10 0.5 PD155 Number of Abnormal Restart 0:Invalid 1:Valid 0 PD150 Auto Voltage Regulation 0~10% 1 PD151 Auto Energy Saving 0 PD156 Proportional Constant (P) 0.0~1000.00% 100% PD157 Integral Time (I) 0.1~3600.00S 5 PD158 Differential Time (D) 0.01~10.00S 0 PD159 Target value 0.0~100.0% 0 PD160 Target value select 0: set by the operator 1:set by external terminals(0-10V) 0 PD161 PID upper limit 0~100% 100% PD162 PID lower limit 0% PD163 Communication Addresses 0-250 0 PD164 Communication Data Method 0-3 0 PD165 0-5 0 PD166 Voltage Rating of Inverter Set according to the model 0 PD167 0 PD168 0 PD169 NULL PD170 Display Items 0-5 7 PD171 Display Items Open 0-7 7 PD172 0 PD173 Rated Current of Inverter 255 PD174 Set according to the model 7 PD175 Inverter Model 0 PD176 Inverter Frequency Standard 0:50Hz 1:60Hz 0 PD177 Fault Record 1 LU PD178 Fault Record 2 Note: —— means no fault record. OL - 1 PD179 Fault Record 3 LU PD180 Fault Record 4 DL PD181 Software Version U - 1.00 PD182 Manufacture Date Year:Month:Week 30627 PD183 Serial No. 65535 PD184 20 PD185 0 PD186 0 PD187 NULL NULL NULL
27th Jan 2014, 10:18 AM #24
Hi,
What sort of motor is it?
Looks like you need to change your main and base frequencies 003 and 004. Also try changing 026 to 0, that way you will get deceleration when changing speeds down so you should really notice if it is working.
27th Jan 2014, 10:50 AM #25Novice
- Sep 2013
- melb
- 16
Hey Uee G'day,
Thank you for your post,
Ok motor is a water cooled spindle, 1.5kw 400mh - 5amp 24000 rpm its a GZD-80
if I change 026 to 0 then the stop button on the panel doesnt work... the spindle wont power down just keeps spinning 026 to 1 panel stop works as intended.
when you say change main and base frequencies 003/004 as I understand it 003 is for frequency you want the spindle to start up at 100/200/300 (whatever number) and 003 is what you are in actually fact adjust when using the up and down arrow keys on the panel - when I use the panel using the up arrow key increasing the numbers the spindle responds and speeds up - using the down arrow key only the numbers change but spindle speed doesnt..
004 should then be set at ???? 005 i would be right at assuming is the rated mh of the spindle which in my case is 400
Thank you for your input.
27th Jan 2014, 10:52 AM #26Most Valued Member
I dont think changing base freq is a good idea.
of to the shed back soon
27th Jan 2014, 11:27 AM #27
Well i've lost my book so i'm next to useless....
026 should not change how the stop button works, just how the motor slows down.
27th Jan 2014, 11:41 AM #28Most Valued Member
Well I cant see anything wrong.
There are some numbers that are different of course. Long shot PD138 you have as 0, my VSD and manual say 20..........I'm not even sure what it does.
I'll type up the rest after breakfast lol
27th Jan 2014, 11:59 AM #29
Hi Stuart, I set the sleep frequency to Daily...
AFAIK It's used when you have multiple pump systems.
Not seeing anything obvious in that parameter list.
27th Jan 2014, 12:07 PM #30
Hi Steve,
Is the motor base frequency 400Hz?
I would try setting 003 to a lower setting and try it. maybe 300.
VFD settings HUANYANG
By morrisman in forum METALWORK GENERALReplies: 25Last Post: 12th Apr 2012, 11:41 PM -
Settings
By ahmmha in forum WELDINGReplies: 0Last Post: 11th Jun 2011, 11:58 AM -
Mig settings for 6mm steel?
By montiee in forum WELDINGReplies: 6Last Post: 22nd Sep 2009, 08:47 PM -
Amp settings
By Unit_01 in forum METALWORK GENERALReplies: 21Last Post: 22nd Oct 2007, 05:06 PM
