Results 31 to 37 of 37
Thread: VFD Settings Huanyang HY01D523B
27th Jan 2014, 01:12 PM #31Most Valued Member
PD003=50
PD004=50
PD005=70
PD007=20
PD008=255
PD009=13
PD010=6.5
PD011=0
PD015=10
PD023=1
PD026=0
PD028=50
PD029=0
PD030=3
PD031=20
PD041=3
PD042=5
PD142=3.4
PD143=4
PD144=1430
You dont have a number for PD083 and PD085. PD150-PD0156 are messed up in your list(but they match up with mine so I assume thats all ok).
But other that a mistake in my settings(PD007=20. it should have been PD011=20), the differences for VSD size(mine is 2.2kW), different motor specs(either my amps is low or yours is high PD142) and that my VSD is set up for braking. I cant see anything that can help you.
Is it a new VSD? might be time to try your luck with your supplier.
27th Jan 2014, 01:40 PM #32Novice
- Sep 2013
- melb
- 16
27th Jan 2014, 01:49 PM #33Novice
- Sep 2013
- melb
- 16
27th Jan 2014, 01:51 PM #34Novice
- Sep 2013
- melb
- 16
27th Jan 2014, 04:52 PM #35Philomath in training
- 6,562
Is this it?
http://www.jinlantrade.com/ebay/invertermanual.pdf
28th Jan 2014, 11:58 AM #361915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
28th Jan 2014, 12:35 PM #37
Hi Ewan,
In case you lose it again... here's another spare copy... Huanyang Library
Those are the ones that Joe Hovel revised and edited, and include the error messages that are often missing from some manuals.
VFD settings HUANYANG
By morrisman in forum METALWORK GENERALReplies: 25Last Post: 12th Apr 2012, 11:41 PM -
Settings
By ahmmha in forum WELDINGReplies: 0Last Post: 11th Jun 2011, 11:58 AM -
Mig settings for 6mm steel?
By montiee in forum WELDINGReplies: 6Last Post: 22nd Sep 2009, 08:47 PM -
Amp settings
By Unit_01 in forum METALWORK GENERALReplies: 21Last Post: 22nd Oct 2007, 05:06 PM
