Results 1 to 15 of 52
10th Jan 2014, 10:57 AM #1Senior Member
- Jan 2004
- Bellingen
- 278
Anyone tried out the Smith and Arrow flap disk and cutting disks?
Just thought I would post this up before I put a bulk order in.
I use a lot of zirconia flap disks in 40grit and the thin cut off disks in a little 125mm angle grinder.
The cut off disks are cheap enough but the flap disks are pretty hefty in the other name brands. Sometimes up to about $10.
I noticed they have some disks as thin as 0.8mm. Anyone tried them out this thin. I just use the regular 1mm thick ones.
The Smith and Arrow brand flap disk work out pretty darn cheap when you buy in bulk from the OZ outlet.
Anyone have an opinion on these? Surely they can't be as good as the regular name brand gear. Are they worth it?
10th Jan 2014, 12:15 PM #2Most Valued Member
- Jun 2012
- SA
- 1,649
I use the S&A 0.8 mm and 1 mm x 75 mm cut off disks in my medium air die grinder and my Waldown toolpost grinder, and they are EXCELLENT.
I've re-ordered a number of times. Great discs and value. Hard wearing and strong.
I've not used anything better. I don't use flap discs, so I can't comment on them.
On one order they ran out of stock, and sent me twice as many for the same price to compensate for waiting an extra week - how good's that ?
But at least you tried.
10th Jan 2014, 12:48 PM #3Intermediate Member
- Jul 2009
- Brisbane
- 48
I have used Smith and Arrow flap discs in 100mm and 125 mm various grits and I was very happy with them.
I will buy them again when I need more.
10th Jan 2014, 03:01 PM #4Most Valued Member
- Australia east coast
- 2,713
I've used hundreds of them in 1mm thickness and the 125mm grinding disks. Not as good as Pferd disks but quite good enough and a lot cheaper. I'd order from them again without thinking twice about it.
PDW
10th Jan 2014, 03:09 PM #5Diamond Member
- Aug 2006
- 1,105
I have used the thin cut off discs they are good value for the $$$ I did a test awhile back on some stainless and the smith a arrow didn't last as long as a flexovit but the difference wasn't worth the extra expense.
10th Jan 2014, 04:38 PM #6Senior Member
- Aug 2009
- Quindanning, WA
- 175
I've used hundreds of the 125mm diameter 1mm thick discs and found them great. I've also used the 125mm flap disks, and while not quite as good as joscos i reckon they are good for the price and will buy again. The only problem has been 100mm grinding discs which have been pretty hopeless... they work ok around the edge of the disc but flat side (underside?) just doesn't have much bite so are really slow at removing material.
10th Jan 2014, 06:03 PM #7Senior Member
- Jan 2004
- Bellingen
- 278
Thanks everyone. Looks like good value! When I get around to putting in an order I will pick up some of the .8mm disks in 125mm as well and give the a go!
10th Jan 2014, 06:54 PM #8Most Valued Member
- Jun 2012
- SA
- 1,649
10th Jan 2014, 07:04 PM #9Intermediate Member
- Nov 2010
- Sunshine Coast
- 21
Smith & ARROW - Thanks
Hey guys
Just wanted to say thankyou to all of you who took the time to help out with this question and make such positive comments about our products. Smith & ARROW is an Australian family owned business and we have worked hard to build it into a company that provides good quality consumables at a fair price. A little while ago we managed to get SAI Global to independently certify all of our cutting and grinding discs against the Australian Standard for bonded abrasives - something we are very proud of. To the user who had a proble with our grinding discs, I would really appreciate it if you could PM me your contact number so that I could give you a call to discuss.
Thankyou all again for your honesty and support.
Ben Ferguson
Managing Director
Smith & ARROW (Australia) Pty Ltd
Tel: 0408 158 407
Email: [email protected]
Web: Smith & Arrow - Long Lasting, Fast Cutting Abrasives for Metal and Concrete
10th Jan 2014, 07:14 PM #10
Just to add my 2 cents I have been using their 1mm disks in 125mm diam and their wire wheels on my angle grinder and I have to say that I agree with all that has been said. Maybe not quite as good as the best brands, but very good value for money. I had a cutting disk that vibrated the other day. The first problem I have had. Still worked ok until I caught it in a cut and made it smaller. Was ok then. Highly recommended and I will be buying them again as well as other products.
Smith&ARROW is online at the moment. Hope they are happy with the replies. Only what is deserved.
10th Jan 2014, 10:35 PM #11Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Great to see an Aussie manufacturer getting it right.
Haven't used them myself but probably will.
Any user feedback on the zirconia belts?
10th Jan 2014, 10:44 PM #12Member
- Sep 2008
- lillimur
- 86
I also like the 125mm cutting discs and have used their linisher belts which I think cut as well as any others,last longer and are tougher.
Have also used their poly discs which work well and their cobalt drills which are also good.
John
10th Jan 2014, 11:08 PM #13New Member
- lara
- 1
Flap discs
I've used the 125 mm zirconia flap discs many times for rust removing and paint stripping.
I found them are very good too. Definitely the cheapest.
I've also got a selection of their 150 mm velcro discs. Not too bad, considering the price.
29th Jan 2014, 12:35 PM #14Intermediate Member
- Nov 2010
- Sunshine Coast
- 21
29th Jan 2014, 03:17 PM #15Senior Member
- Aug 2009
- Quindanning, WA
- 175
Hi Ben, I got a PM but there was no text in the message. Anyway I use 100mm grinding discs.
neil
Chinese cutting disks not equal to Flexovit
By Franklin in forum METALWORK GENERALReplies: 36Last Post: 20th Aug 2011, 07:37 AM
