Results 1 to 15 of 16
Thread: Milling vice accuracy ?
6th Jan 2014, 10:40 PM #1
Hi
I bought a 4" milling vice from OZMEstore some time ago . I was initially impressed with its accuracy but lately it has not been behaving well .
As the jaws clamp onto the work, the work piece it pushed out of alignment , sideways and upwards . I have resorted to using a depth micrometer in order to get the work level in the vice - I use top face of the jaw as a reference for the mic.
Maybe something has worn , but I haven't used it that much . It is Asian of course .
One thing I have noticed is the base is not flat , the vice rocks about .003" from front to back - I checked this on my surface plate and it does this rocking on the 45 mill table as well .
Mike
6th Jan 2014, 11:37 PM #2
Hi Mike,
Do you use parallels and a deadblow hammer/lump of lead/copper hammer etc to make sure the part is seated properly as you tighten up the vice?
For doing small work i reckon the screwless vices are the way to go. 63mm 2 5" QKG Quick Action Precision Toolmakers' Vise Free Postage | eBay
I must say that my Glacern vice (ex GQ's) makes the Chinese vices look like rubbish. They are not cheap though.
7th Jan 2014, 12:04 AM #3Golden Member
- Aug 2012
- Australia
- 645
Ewan, did you know that your Glacern is actually a Vertex? Glacern gets the vices from Vertex and finished them. I saw some similarities with my Vertex and went hunting for information. I am trying to convince myself that I need a Kurt..
Mike, I assume your vice is an anglock - designed to not lift as it clamps? Design aside if I clamp hard enough in my Vertex anglock the part lifts. If it won't seat properly with a tap, I tend to rotate the part. Usually ends up seating for me.
7th Jan 2014, 12:13 AM #4
Hi Mike,
How well do the jaws line up without anything in them.
If the part you are clamping isn't parallel you need to set up a half round block. Plus what Ewan said about parallels and soft face hammer to seat the part.
Just tap as you tighten up the vise so that the parallels don't move. ( can't be pulled out by hand. )
7th Jan 2014, 12:32 AM #5
Sort of correct, but Glacern quality is a cut above Vertex, and Vertex is pretty good. Glacern get their castings from Taiwan, but all the grinding and precision stuff is done in the US.
I've got Vertex, but I'm looking for second hand Kurt or Glacern. Matched pair would be nice
7th Jan 2014, 08:41 AM #6.
- 6,459
Why not emulate Karl with a trio of Rohms?
7th Jan 2014, 08:56 AM #7Most Valued Member
- 4,258
7th Jan 2014, 09:22 AM #8.
- 6,459
A close up of nice for you Richard.
7th Jan 2014, 09:25 AM #9Most Valued Member
- 4,258
7th Jan 2014, 09:40 AM #10.
- 6,459
?? look here if you are interested. Window to my workshop 47 « From the Workshop
7th Jan 2014, 09:58 AM #11Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
Hi BT,
Beautiful set of vice, I really like the adjustable jack feet on the hold down clamps. Looks like a doable mod on some of mine.
Bob
7th Jan 2014, 10:06 AM #12
I have that 63mm vise from Ozmestore and it is a very nice little vise, but I seem to remember paying about $45 for it, that has gone up quite a bit.
Yes I noticed those as well, seems very easy to use. Had a browse through some of the posts on that blog, wow what a workshop and what quality of work on display.
Thanks for showing that BT
7th Jan 2014, 01:16 PM #13Senior Member
- Apr 2010
- ringwood vic
- 251
Hi Mike,
I have had the 125mm version of the Ozme vice for about 3 years now, just ran a dial indicator over it, and it's still dead nuts level in both planes, but I do find I need to nip up the jib strip bolts every six months or so or work starts to climb up when tightening it.
Regards,
Martin
7th Jan 2014, 01:47 PM #14Most Valued Member
- 4,258
7th Jan 2014, 09:21 PM #15
Shaper vice and milling vice
By morrisman in forum METALWORK GENERALReplies: 6Last Post: 5th Sep 2012, 12:06 AM -
any one know this milling vice ?
By thorens in forum METALWORK GENERALReplies: 8Last Post: 31st May 2012, 11:29 AM -
A good way to key a milling vice
By steran50 in forum METALWORK GENERALReplies: 9Last Post: 4th Jan 2012, 06:46 AM -
Milling Vice
By eskimo in forum METALWORK GENERALReplies: 27Last Post: 17th Aug 2011, 06:00 PM
