Results 46 to 60 of 79
19th Dec 2013, 06:04 PM #46
19th Dec 2013, 06:09 PM #47Most Valued Member
- Jun 2012
- SA
- 1,649
OK I will take some shots.
The only downside of what I'm doing is that the Dufor has to be machined down to about 2 mm wall thickness, which is not as much as I would like - but I'm using what I have, and if it wears out (unlikely) I will have to BUY a thicker walled bush - crikey, spend money
The alternative is to machine out the centre in the pulley to the OSD of the Dufor, but I don't want to do that as it could weaken it. The pulleys are under fair pressure when tensioned.
This will work, and it should out last me, so this is how it's going to be.
But at least you tried.
19th Dec 2013, 06:13 PM #48Philomath in training
Yes. I think Andre is using an old photo from http://www.woodworkforums.com/f65/ta...-parts-151445/
19th Dec 2013, 07:31 PM #49Most Valued Member
- Jun 2012
- SA
- 1,649
Had a thought for making the bush in the idler pulley last longer
I don't know if this is the case for all these BS clones, but here goes.
One problem with these BS is that there's no way to lubricate the bush/ spindle combination in situ.
That's probably why mine wore out so badly. Never been greased.
HOWEVER, thinking over a glass of red it hit me that the bolt hole through the centre of the shaft that takes the bolt to keep the pulley on is deep enough that it goes to at least the centre of the bush/pulley.
So here's the plan - why not drill through the side of the shaft into that central thread hole, in line with the centre of the bush.
Then tap a thread of the correct type onto a grease nipple.
You can then grease the bush by removing the bolt, screwing in the nipple, add grease, reverse process, job done in a few minutes.
If the shaft is too hard to drill I will grind a hole with a burr in the die grinder.
What do you recon
19th Dec 2013, 08:59 PM #50Philomath in training
Is the bolt gutsy enough that you can drill down the centre of it (probably only needs to be a 3mm or so hole)? That way you could do that, mount a grease nipple on the head of the bolt and go from there.
I've found that if I have to (even partly) disassemble things, maintenance does not happen as often as it does when everything is there.
19th Dec 2013, 09:09 PM #51Most Valued Member
- Jun 2012
- SA
- 1,649
20th Dec 2013, 06:17 AM #52Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Not sure about a hole in a hardened shaft Rob, they can be prone to breakage. Mine has a button oiler in the boss of the pulley.
Could you drill and tap a hole in 'your' pulley boss for a grease nipple.
Phil
20th Dec 2013, 07:29 AM #53Most Valued Member
- Jun 2012
- SA
- 1,649
20th Dec 2013, 05:58 PM #54Most Valued Member
- Jun 2012
- SA
- 1,649
Pulley bush and shaft repair done - 100% OK
Made up a sleeve to go over the damaged shaft.
Did away with the poxy spacer by extending the sleeve and bronze bush - this gives rear face support to the pulley.
Tack bronzed the sleeve onto the original shaft at one end. Quench hardened the sleeve.
All fitted and works great with absolutely no pulley weave or runnout.
May add a greaser later.
Here's some photos that give an idea of how I did it.
The wall thickness of the bronze bush can be seen in the last photo.
Fitted the new blade and cuts great. Have yet to fine tune the adjustment.
Two of the blade rollers are heavily grooved so may swap them over as well.
With the 1 HP motor it cuts effortlessly.
20th Dec 2013, 06:34 PM #55
Nice job Rob, that fix will last the saw out.
If you dont have new bearings on hand I got away with turning the bearings around and only replaced them a few years back after one seized.
DaveUsing Tapatalk
20th Dec 2013, 07:03 PM #56Most Valued Member
- Jun 2012
- SA
- 1,649
20th Dec 2013, 07:05 PM #57
I would swap them as the blade will want to run back in the groove.
DaveUsing Tapatalk
20th Dec 2013, 07:09 PM #58Most Valued Member
- Jun 2012
- SA
- 1,649
Might as well I suppose.
Once that's done i can use it to make up a vise jaw and a locator to mate with the screw thread thingy under the bed.
It certainly cuts through steel well.
Glad I bought it.
20th Dec 2013, 07:19 PM #59
If you need to cut the vise jaws on this saw a G clamp works well to hold it and screw a bolt in the hole in the bed to rest it up against
Using Tapatalk
20th Dec 2013, 09:07 PM #60Most Valued Member
- Jun 2012
- SA
- 1,649
A new twist on things
After fixing the bearing and shaft I still had about 1/8" vertical runout on the cut, and with a square on the cutting plate you could see the blade move out at the top of the arm movment.
There is no adjustment on the swing arm, and I thought, I wonder if the base is twisting on the floor surface.
So I put a steel plate under a leg to induce twist and watched the blade travel v the square.
That was the problem.
Moved the saw to a flat area of floor and it's within 1 mm through the cut arc.
The stand is pretty crummy as provided. If you were to make a solid stand and use pull down bolts to mount the saw (instead of the side mount arrangement), you could effectively use shims to induce sufficient twist to get perfect swing arm travel.
Interesting stuff.
rong fu
By texx in forum METALWORK GENERALReplies: 5Last Post: 22nd Oct 2013, 05:50 PM -
Rong Fu Vs Macc Horizontal bandsaw
By loggerhead in forum METALWORK GENERALReplies: 4Last Post: 9th Feb 2013, 03:51 AM -
Rong Fu Metal band saw
By morrisman in forum METALWORK GENERALReplies: 4Last Post: 17th May 2012, 09:53 PM -
Wot have i dun rong?
By 46150 in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 2Last Post: 21st Aug 2008, 06:36 PM
