Results 1 to 13 of 13
Thread: Pcd
16th Dec 2013, 12:30 AM #1future machinist
- Mar 2008
- nowra
- 1,598
Pcd
I have to drill 6 holes on a 59 mm pcd , what are the x, y coordinates for some reason I can't get my head around bolt circles or PCDs
Andre
16th Dec 2013, 12:46 AM #2Most Valued Member
Hole 1 29.50 0.00
Hole 2 14.75 25.55
Hole 3 -14.75 25.55
Hole 4 -29.50 0.00
Hole 5 -14.75 -25.55
Hole 6 14.75 -25.55
16th Dec 2013, 12:47 AM #3Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
Moving clockwise with the first point on the X axis to the right of the origin
0, 29.5
14.75, -25.55
-14.75, -25.55
0, -29.5
-14.75, 25.55
14.75, 25.55
Edit. Stu types quicker than I do
16th Dec 2013, 12:49 AM #4Most Valued Member
I can not tell a lie, I wouldnt have a clue how to do it with a pen and paper.
Pitch Circle Calculator
16th Dec 2013, 12:59 AM #5Most Valued Member
If you're using a mill without a DRO it might be easier to "start at the bottom left corner"
0,0 is at BOTTOM LEFT
Hole 1 59.00 29.50
Hole 2 44.25 55.05
Hole 3 14.75 55.05
Hole 4 0.00 29.50
Hole 5 14.75 3.95
Hole 6 44.25 3.95
I think I'd go 4,5,3,2,6,1
16th Dec 2013, 01:12 AM #6Most Valued Member
Hi welder, the radius of your circle will give you your 6 points to centre punch. For the coordinates, multiply the given dimensions by the PCD required, from the vertical centre line is 0.43301, from the horizontal centre line it is 0.25.
This came from MEW number 205 page 34, it has hole pitch circle diameter information from 3 to 12 holes.
Will try to load the pages onto the library if anyone thinks it may come in handy???
< .................................................O
<......................................... O............. O -
<.......................................................... 0.25
< ................................................ O..... I
<.................................................. I..... 0.43301
Not my best drawing but hope this helps,
PS when I started to type this there were no other answers, JEES I must type slow.
16th Dec 2013, 01:35 AM #7Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
pcd
dont you just scrib a circle and divide it into 6
16th Dec 2013, 06:36 AM #8Philomath in training
- 6,563
If you buy yourself a Zeus book it has all the ordinates in the back up to some ridiculously large amount. (get someone to get you one for Christmas)
16th Dec 2013, 07:15 AM #9
16th Dec 2013, 07:52 AM #10Pink 10EE owner
- 6,218
I thought that is what DRO's were for
16th Dec 2013, 07:56 AM #11Most Valued Member
- 4,258
co ordinates of a map...lol
I'm glad I have a dro....for when i will need it...probably still take me longer to work out than asking you guys
16th Dec 2013, 08:29 AM #12Most Valued Member
- 4,890
Have you just considered marking it out with dividers.
Depending on the accuracy you require you should be able to get it to within a few thou if not spot .
It would be a good learning exercise for you in marking out.
Sin(180/N) X PCD. N= number of holes.
16th Dec 2013, 09:28 AM #13future machinist
- Mar 2008
- nowra
- 1,598
Thanks guys I Got it done
Andre
