Results 1 to 3 of 3
10th Dec 2013, 11:14 AM #1Tiptoeturtle Guest
Help sought in identifying the make of lathe a change gear fits
I am attaching a picture of a change gear for a metal lathe. I am trying to find out what type of lathe it is meant for.
It has 116 teeth.
The bore is 9/16".
The thickness is 7/16".
I think it is cast iron.
The outside diameter is about 6 1/2".
The words "TURNING GEAR" and the abbreviation "116 T" are cast in it.
The teeth mesh with the teeth on Hercus change gears, but the bore is wrong for an Hercus lathe (I think Hercus uses 5/8" whereas this is 9/16").
This was an orphan among some other gears in a lot of 10 gears I bought secondhand.
Donald
10th Dec 2013, 12:07 PM #2Most Valued Member
- 4,887
Not sure anyone will be able to help with the question you are asking.
Any lathe in essence could have any type of change gear as long as there is enough room for them to fit.
The gear you have appears to be an 18DP gear.
Hercus use 18DP gears on the change gears for there 9" and 260 lathes,they use a different DP on there larger machines.
The thickness is a 1/16" wider than a Hercus change gear for the 9" and 260.
The bore of 9/16" is correct for the 9" and 260 change gears.
11th Dec 2013, 11:22 AM #3Tiptoeturtle Guest
Pipeclay,
Thanks for the information. I think I gave wrong figures somehow in my original message, sorry about that, thanks for the correction(s).
Here's a picture of the unknown 116 tooth gear alongside / meshing with an 80 tooth Hercus gear (this 80 tooth is from a 1946 Hercus).
Donald
Lathe thread cutting change gear calculator
By Vernonv in forum METALWORK GENERALReplies: 61Last Post: 20th Dec 2015, 08:38 AM -
SOLD: Myford Metric Change Gear Set
By SurfinNev in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 10th Jan 2013, 09:39 AM -
Hercus Change Gear Diameter
By pipeclay in forum THE HERCUS AREAReplies: 7Last Post: 15th Jun 2009, 01:41 AM -
Hercus Change Gear Guard
By pipeclay in forum THE HERCUS AREAReplies: 17Last Post: 2nd Sep 2008, 03:36 PM -
Sheraton gear change chart?
By warlock in forum METALWORK GENERALReplies: 4Last Post: 29th Jun 2005, 02:49 PM
Members who have read this thread: 0
There are no members to list at the moment.
