Results 16 to 24 of 24
Thread: Mower deck rebuild
9th Dec 2013, 08:56 PM #16
10th Dec 2013, 06:31 AM #17Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi pipeclay,
I was thinking along the lines of the 4140 as well as I wasn't sure if the 1020 would be good enough.
With the stainless, I find it easy to machine which is probably due to doing my apprenticeship in the food industry.
It was my job to rebuild the can closers and the first job was to pull all the shafts out and make new stainless ones.
Do you think the stainless would be good enough for a shaft like this as it has a fair bit of stress in use.
Phil.
ps I don't mind a bit of levity
10th Dec 2013, 07:43 AM #18Most Valued Member
- 4,890
I cant see why not,as it is used in prop shafts and torque would be similar or even greater than the mower deck.
If you already have it might as well use it.
10th Dec 2013, 01:39 PM #19Most Valued Member
- Australia east coast
- 2,713
Any excuse is a good excuse, is why. It's far enough away not to be a problem and there are plenty of others so no point in killing it or chasing it off.
Don't know why people think stainless is difficult to machine, I machine 316 all the time. It is soft WRT 4140 and similar though.
PDW
10th Dec 2013, 02:56 PM #20Cba
- Aug 2007
- 68
- 1,410
Phil, I am not sure if stainless is such a good idea in this case. The nice stainless shaft will be in intimate contact with a plain carbon steel blade. Add some grass juce electrolyte between the two, and the nice stainless shaft may corrode, just as if it was iron and possibly even faster.
10th Dec 2013, 03:33 PM #21
10th Dec 2013, 08:11 PM #22
I did wonder considering your dislike of mowing. If he's far away it is no problem. I only worry about them around the house area which includes workshop and implement shed. SWMBO does not like them in the house. She went to the toilet one day and found one in the wash basin. I am against running them over on the road. Rather pointless I think.
10th Dec 2013, 08:13 PM #23
11th Dec 2013, 06:17 AM #24Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Great advice guys, a couple of things I didn't think of like stainless prop shafts, they do cop a flogging so should cope with a mower, and also the corrosive effects of that combination.
It's never gunna just be simple, is it.
Oh, and you should know by now Ray that I'm always in a constant state of counselling .
I checked the rest of the mower out and it seems there isn't much metal left that doesn't have a crack in it so the engine will be used to finish off Dads rotary hoe (another job out of the way)
Phil
