Results 1 to 5 of 5
8th Dec 2013, 10:21 PM #1Member
- Jan 2008
- Camden NSW
- 75
Bridgeport Series 1 Mechanical feed gearbox
Does anyone have an original Bridgeport mechanical feed gearbox for a series 1 mill. I have just aquired a series 1 Bridgeport with the old style gearbox that looks like a lathe quick change gearbox.
It needs a bit of TLC.
Many thanks
Garry
9th Dec 2013, 07:54 PM #2Most Valued Member
- Australia east coast
- 2,713
9th Dec 2013, 09:36 PM #3Member
- Jan 2008
- Camden NSW
- 75
Bridgeport Mechanical feed
I was trying to locate a drawing of the gearbox or some info, found that there was a cotter pin (shear pin) missing, replaced that and away she went but a little noisy. I am only using way oil in gearbox but after pulling off the high / low range side cover plate it has had some water in it at some stage and gears are pitted.
Garry
10th Dec 2013, 07:57 AM #4Senior Member
- Dec 2010
- Syd
- 492
Without hearing it, possibly normal, they usually sound like a mechanical catastrophe!
11th Dec 2013, 06:54 AM #5Member
- Jan 2008
- Camden NSW
- 75
The noise appears to be a bearing rumble or rust particles stuck in a gear, You can feel the rumble through the feed handle and shaft. I will do a bit more cleaning to try and find the problem.
Many thanks for all the help.
Garry
Engage/disengage feed levers while feed rod is rotating al960b
By Ben Dono in forum METALWORK GENERALReplies: 8Last Post: 11th Sep 2012, 08:11 PM -
Bridgeport
By robbo37 in forum METALWORK GENERALReplies: 0Last Post: 28th Jul 2012, 02:48 PM -
bridgeport
By rfurzer in forum METALWORK GENERALReplies: 11Last Post: 12th Apr 2011, 10:00 PM -
Ebay Bridgeport
By browny in forum METALWORK GENERALReplies: 16Last Post: 26th Sep 2007, 10:51 PM
