Results 16 to 18 of 18
Thread: Tapping 2M
11th Dec 2013, 09:14 AM #16
Hi Brian,
If i was tapping so small i would want to have both the tap wrench and the part in my hands so i could feel any twisting of the tap etc. If you counterbore from the bottom with a 2mm drill you can then use the counterbore as a guide for the tap and it will have to go in straight. I'd also try to get hold of a gun nose tap, these push the chips out the bottom of the hole and you do not need to constantly back them off to break the chips up. Most of the taps i have broken have jammed when backing them off, not when doing any actual cutting.
11th Dec 2013, 09:40 AM #17Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Number Drills
Brian
Here are some number drills that could solve your tapping drill problem, if you cannot get the metric ones.
No 52 .064" dia
No 51 .067" dia
No 50 .070" dia
No 49 .073" dia
regards
Bruce
12th Dec 2013, 12:04 PM #18Senior Member
- gold coast
- 303
Thanks Ew and Bruce,
from both of your advice I beleve the problem will be solved. I can do with a few number drills! and counterboring form the bottom to use as a guide is such good sense!
regards Brian
DIY tapping chuck
By jhovel in forum METALWORK GENERALReplies: 34Last Post: 9th Aug 2012, 12:13 AM -
Tapping Problem
By Bidgee in forum METALWORK GENERALReplies: 10Last Post: 31st Jan 2012, 09:59 AM -
Help with tapping
By snowyskiesau in forum METALWORK GENERALReplies: 20Last Post: 21st Sep 2009, 03:41 PM -
Tapping holes
By ClintO in forum METALWORK GENERALReplies: 9Last Post: 16th Sep 2005, 11:10 PM
