Results 16 to 29 of 29
Thread: Making a sine plate
26th Nov 2013, 08:36 PM #16
Hi Bruce,
The projects you did in your apprenticeship always amaze. The descriptions always include terms like ground, hardened and lapped. I always enjoy your posts on such things. I guess they don't do anything like that anymore?
26th Nov 2013, 08:42 PM #17
Anyway, contrary to Stu's smart### comments the plate just isn't quite finished....yet(I blame having to replace the water pump gasket in SWMBO's car today) But there are plenty of pics.
Actually i'd like to case harden at least the top of the bottom plate and the top of the top plate....so, like always the domino's go on. I need the sine plate to finish my mag V block. I need an oven to finish my sine plate....What next
The guts of the machining is now done, just need to mill the plates to length and then layout, drill and tap some work holding holes and the roll fixing holes.
Pics should be pretty self explanatory. Damn its nice having a mill with a nodding head...i do miss having a quill though.
27th Nov 2013, 01:31 AM #18Golden Member
- Oct 2012
- Australia
- 621
27th Nov 2013, 07:59 AM #19Pink 10EE owner
- 6,218
Yes nodding is a very under appreciated thing to have on a mill...
20131013_202328.jpgGold, the colour of choice for the discerning person.
27th Nov 2013, 09:30 AM #20
Thats ok, i won't need them till i have an oven made etc.....that should take at least till lunchtime tomorrow.
My little Suburban plate has a .200" step as well as the zero surface. I have seen some plates with the ends of the roll machined down instead, but since i don't have a cyl grinder it will be done as a .100" step. For anyone who hasn't used a sine plate or was wondering about the step, it means you can set really low angles by using say a .1001" or .102" etc block in the step.
27th Nov 2013, 09:32 AM #211915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
27th Nov 2013, 10:15 AM #22Pink 10EE owner
- 6,218
That is the beauty of the models where you can slide the ram that the head is on in and out, position the head where you want...
Yes it is the 10EE saddle being machined for turcite..Gold, the colour of choice for the discerning person.
2nd Dec 2013, 08:18 AM #23Most Valued Member
- 4,258
2nd Dec 2013, 08:39 PM #24Pink 10EE owner
- 6,218
I either make up a gauge or set something up at the appropriate angle, then align it with the axis I am angling, then put a DTI on the quill and run the quill up and down...
If it is rough and ready, just use the graduations on the head... depends on how accurate you want it... When I did the 10EE saddle, I actually ground a right angle triangle up using the magnetic sine plate to get it good to 32.5 degrees (the V way included angle is 65 degrees) It was probably overkill, but teaches new skills...Gold, the colour of choice for the discerning person.
4th Dec 2013, 01:11 PM #25Most Valued Member
- Australia east coast
- 2,713
24th Jun 2014, 08:58 PM #26
Well i have a job to do that i need the sine plate for. So back to it! At this stage hardening will have to be left, it may be nearly impossible to do it later but.......
Anyway, i have made the hinges
Bolted and tapered pined one end on
Then set up the DTI to ensure the roll is parallel to the bottom plate, ready for taper pins
24th Jun 2014, 09:18 PM #27
Looks good Ewan, any thoughts on what you will do for the top as far as fixture holding goes? Lots of tapped holes? T slots?
PS I see the grinder is getting a workout.. Incidentally I did a pic based downfeed controller for slotting mode on the SG last week, If you can rig up a solenoid to kick the downfeed wheel, it's a piece of cake.
24th Jun 2014, 11:04 PM #28
Thanks Ray,
I have tapped maybe 27? M8 holes for mounting, plus i bought a 450x150 mag chuck cheap from Grays some time back for it.
The mounting spot is there for a solenoid, i would like to add one but it's not a huge priority right now. I'll need to find a way to signal the PIC when the cross feed changes direction, i should be able to piggy back of the existing switches for that. It would be really nice if i could find a wiring diagram and see how it was done factory. As you saw all the blank spaces are there on the pendant for the controls.
27th Jun 2014, 09:17 AM #29
Well i set up and ground the top plate for the rolls today. I carefully sparked out each one at exactly 5" on the cross dial. On to the rock and with the master gauge and DTI i checked the distance, but it is .0055" small. Now that has me scratching my head! I might have to pull the gauge apart and lay it on the grinder so i can use it to position the wheel.
Sine bar setting taper attachment
By Retromilling in forum METALWORK GENERALReplies: 24Last Post: 3rd Nov 2013, 07:54 AM -
Sine bar errors article
By morrisman in forum METALWORK GENERALReplies: 0Last Post: 21st Sep 2012, 04:30 PM -
Sine Bars
By Ueee in forum METALWORK GENERALReplies: 3Last Post: 30th Aug 2012, 11:26 PM -
A Delicacy from Placentia - Kingmann White MINI-SINE Bar
By Anorak Bob in forum METALWORK GENERALReplies: 6Last Post: 11th Aug 2012, 08:57 PM
