Results 16 to 27 of 27
Thread: 3 jaws chuck runout questions
22nd Nov 2013, 11:03 AM #16Most Valued Member
Hi Peter,
I'd be happy with the 0.04mm at 50mm dia.
Is there still 40" runout out at 25mm?
22nd Nov 2013, 11:27 AM #17Golden Member
- victoria
- 499
22nd Nov 2013, 07:53 PM #18
40 inch runout?
22nd Nov 2013, 08:02 PM #19Golden Member
- victoria
- 499
22nd Nov 2013, 08:45 PM #20Most Valued Member
22nd Nov 2013, 11:20 PM #21Diamond Member
- N.W.Tasmania
- 1,407
Hi Peter, I presume that you mean 0.4 mm, and not 0.04 mm, because if you only have 0.04 mm runout, and if it is consistently close to that figure over a good range of shaft diameters, you have a better chuck than most. 0.04 mm equates to just over one and a half thou, which is better than many collets would achieve.
On the other hand 0.4 mm is just under 15 ¾ thou, and a more likely result for an inexpensive Chinese made chuck, especially if there was any imperfection in its assembly to backing plate and headstock.
If the runout is reasonably consistent in amount and and direction (for example between 12 and 16 thou, towards jaw No.2 say) when chucking a large range of diameters, you could modify the chuck and maybe also the backing plate to make your own version of a Set-Tru chuck, and you would be able to dial it in much closer. In all probability though, the runout will vary somewhat, possibly both in magnitude and direction, so it might not be worthwhile unless you make multiple parts from identical stock, when you could dial the chuck in for that size stock, and have the convenience of the 3 jaw with near the accuracy of the 4 jaw chuck.
There has been lots of discussion on this subject, in many forums over the years, and Google will point you to them, but I have put a couple of links in which may be of interest if you want to tune your chuck up a bit more, that is if it has runout of 0.4mm, if it only has runout of 0.04mm, you want to guard it well, and only feed it with bright bar or previously machined workpieces, or else you will soon loose that accuracy.
The first 2 links are to examples of home brewed "Set-Tru" type chucks, and the last link is to the manual of the Asian made South Bend adjustable chucks, hope you find it useful'
Rob.
HomeShopTech
New (to me) chuck, and making a backplate - Home Model Engine Machinist
http://cdn0.grizzly.com/manuals/sb1314_m.pdf
23rd Nov 2013, 12:08 AM #22Golden Member
- victoria
- 499
hello Rob.
you might got me on this
i was using the 0.01mm~10mm Mitutoyo dial indicator and the runout was 4 marks on the dial . so i thought it means 0.04mm ? or i'm was wrong ?
the whole dial have 100 marks in ten sections .
thanks for the links.i will have some reading tomorrow .
also the process i did was re-machine the back plate so it run true on the lathe and then re-install the chuck when i re-machine the back plate i give the register a few thous smaller than before so i can have some to adjust and it did what i wanted to .
regards
Peter
23rd Nov 2013, 09:54 PM #23Diamond Member
- N.W.Tasmania
- 1,407
Hi Peter, That does sound like your dial indicator reads to 0.01 mm, I assume that the needle rotates 10 times to measure the 10 mm. I would also expect that it has a secondary dial which counts full revolutions of the needle on the main dial like the one in this link. If your chuck is consistently giving results anything like those you have reported, it is much better than you would normally expect, and well worth taking extra good care of IMO. Cheers,
Rob
Google Image Result for http://www.powertoolsdirect.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/m/i/mitutoyo-2047s-dial-indicator-0-01mm-grad.jpg
23rd Nov 2013, 11:41 PM #24Golden Member
- victoria
- 499
25th Nov 2013, 03:01 AM #25
Hi Thorens,
I would have liked to get less runout but 1.5thou is good enough for me. If I really want to be precise I use the original Prat Burnard chuck. I get less than half a thou consistently from that one. FWIW the only reason that I bought a 125mm chuck was because I have lost the outside jaws for the PB chuck and needed to be able to hold an 80mm dia workpiece for another job.
PB can supply a new set of jaws for the original Myford chuck at the expense of both arms and legs !!!.
I don't think that there is a lot to choose between Indian and Chinese chucks. In my case I think someone screwed up and mixed up the jaw sets between two chucks, particularly since the serial numbers were different. One last criticism both the new chucks do not have the jaw position marked ! I like to know which slot each one lives in.Best Regards:
25th Nov 2013, 06:47 AM #26Senior Member
- Jul 2012
- Griffith NSW
- 435
You can always do a test fit of the jaws in different positions until you find the best fit. There are only 3 possible fitments, the jaws still have to be placed in the correct order. Once the most true setup is found, back em out and stamp the chuck.
25th Nov 2013, 10:35 AM #27Golden Member
- victoria
- 499
Daryl's Chuck has RUNOUT!
By DarBee in forum METALWORK GENERALReplies: 15Last Post: 8th May 2013, 01:10 AM -
TOS Chuck Runout
By Anorak Bob in forum METALWORK GENERALReplies: 17Last Post: 7th Mar 2011, 03:01 PM
