Results 1 to 4 of 4
    Jan 2009
    perth wa
    110
    Default Engaging back gear on ML7 Myford
    I trying to help a friend who was given a Myford lathe. I did have one of these some years ago can anyone remind me how engage the back gear I thought it was a Allen keyed head bolt that you undone an slid across
    6,480
    Quote Originally Posted by woodfast View Post
    On my ML7LB you have to move the lever next to the chuck upwards to engage the bull wheel after you have toggled the small lever in the bull wheel to disconnect the drive between the two concentric shafts !
    Cor ! That sounds more complicated than the five seconds it takes to do it.
    Anyway HTH.
    Jun 2007
    Ipswich QLD
    68
    1,997
    Thats correct on the bull wheel rotate till you locate the allen head bolt can be ARPIA with an allen key which is to long, then lever on the right lift up on my ML7 anyway.
    6,480
    Quote Originally Posted by wheelinround View Post
    On mine the bull wheel has a very short lever that rotates a half circle cam in and out of a recess on the driving shaft. The earlier machines may have had an allen socket to move the cam. I find it very convenient to engage the back gear selector when changing the chuck because it locks the drive and therefor the spindle making it easy to unscrew the chuck. You do have to remember to disengage the back gear selector before applying drive. It does make the belt squeal a little if you forget !
  1. Myford Gear train
    By wheelinround in forum METALWORK GENERAL
    Last Post: 30th Apr 2013, 06:27 PM
  2. SOLD: Myford Metric Change Gear Set
    By SurfinNev in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 10th Jan 2013, 09:39 AM
  3. Broken Myford ML7 Bull Gear
    By swarf4ages in forum METALWORK GENERAL
    Last Post: 16th Sep 2012, 03:31 PM
  4. Gear tooth count on Back/Bull Gear.
    By pipeclay in forum THE HERCUS AREA
    Last Post: 6th Jan 2010, 11:56 AM
  5. Rebuilt back gear
    By bitza500 in forum THE HERCUS AREA
    Last Post: 19th Oct 2008, 08:41 PM
