Results 1 to 2 of 2
Thread: Black acetal leadcrew nuts
13th Nov 2013, 07:33 PM #1
Hi
Has anyone an opinion re: the use of copolymer acetal material for leadscrew nuts . The link Ewan posted seems to suggest it is a viable and more economic option , instead of the expensive bronze nuts
Mike
13th Nov 2013, 09:01 PM #2
Hi Mike,
Which link was that? One of the ones in Michaels thread? I have read both positive and negative comments on using pom, but the one thing that keeps cropping up is that it does wear quickly and you really need some form of backlash adjustment.
I can get small slugs of Bronze locally specifically for nuts, not sure on the grades as i have never really needed to pay much attention. They are between $5 and $15 each depending on size.
Chinese Black Nuts, Bolts & Washers
By Jim Ferrous in forum METALWORK GENERALReplies: 11Last Post: 31st Oct 2013, 08:59 PM -
Online sources for Acetal 'Delrin' solid rod?
By martrix in forum METALWORK GENERALReplies: 15Last Post: 21st Feb 2010, 01:14 PM -
Delrin or Acetal... where can I buy some?
By Malfie in forum METALWORK GENERALReplies: 3Last Post: 11th Jul 2007, 06:49 PM
