Results 1 to 9 of 9
5th Nov 2013, 05:30 PM #1Banned
- Apr 2013
- adelaide
- 293
Scalloping round tube/pipe for T joints
For anyone interested, instead of using a grinder to scallop round tube, I use the bandsaw. I first set the BS at around 39 degrees then move the stop out a few inches to clear the blade. I then measure from the stop to the end of the tube and make the first cut, then swing the tube around 180 degrees set the end of the tube the same distance from the stop and make the second cut. I’ve been using this method for years, better than making sparks fly everywhere, makes a perfect joint and it's a hell of a lot quicker – particularly if there are a lot of scallops to do. The pics should be self explanatory.
5th Nov 2013, 09:14 PM #2Most Valued Member
- 5,942
That's how I do it also, except that I set the stop. Thanks for showing others how to do it.
5th Nov 2013, 09:52 PM #3Most Valued Member
That's nice. I have another option but it's perhaps not as nice. I inherited a hand operated hydrocrop tool. It shears off the pipe and flattens the end in one go. Like I said, not as nice though.
5th Nov 2013, 11:03 PM #4Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,277
Thanks for that. I learn something new....
I did this a few weeks ago, but I used my Mill. ( I was lucky to have a 25 mm end mill. )
Your method works best if you don't have a mill..
6th Nov 2013, 07:46 AM #5Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
The belt sander does a good job and you can easily cut any angle, very handy if you need a few pipes cut. The only downside is you need to have a few drum sizes. I do have an angle calculator that can be downloaded from the web for cutting on the band saw, I notice that there are now apps for mobile phones as well.
Bob
6th Nov 2013, 11:06 AM #6Most Valued Member
6th Nov 2013, 11:30 AM #7Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
simonl,
If you saw my welding skills you would see that I need very even gaps to do even a halfway reasonable job.
Bob
7th Nov 2013, 02:28 PM #8
7th Nov 2013, 04:21 PM #9Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
Hi Graham,
Thanks for your reply.My belt sander/grinder is one I built some time ago,they are very handy for all sorts of work. I did post it up under "Your Latest Projects" posts 138,141 & 241. I now have three separate tool bars that I can change very easily-no tools required. If you have some spare time building one is a great project.
Bob
Cutting pipe welding saddle joints
By jhovel in forum METALWORK GENERALReplies: 4Last Post: 29th Apr 2012, 06:03 PM -
DONE: Underwood, industrial Round Tube cutter
By Dano48 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 20th Nov 2010, 04:56 PM -
Pipe Fitting - Tube Coping Calculator
By NewLou in forum METALWORK GENERALReplies: 1Last Post: 10th Oct 2010, 09:43 PM
