Results 1 to 4 of 4
    Nov 2010
    Gippsland Victoria
    733
    Default router bits in lathe to mill aluminium - youtube video
    Have a look at this video. He describes how he made the block.
    Sherline Cross Slide Accessory Block - YouTube
    He used a router bit in his lathe to mill a V groove in the aluminium block.
    I've bumped into this idea a few times in various woodwork forums - using wood router to shape aluminium and have seen some posts where people have said that they use ordinary wood lathe chisels to shape aluminium spindles on a wood lathe.
    Have always been a bit wary about doing this and have never tried using router bits or chisels to shape aluminium.
    Bill
    Last edited by steamingbill; 28th Oct 2013 at 11:20 PM. Reason: inserted last line
    6,475
    Hi Bill,
    I've used woodworking router bits in the mill to machine both aluminum and brass a number of times. I've also used a 82 degree HSS countersink to mill a V groove in a mild steel plate for use as a finger plate.
    I've also tried machining aluminum using the router but its a bit too fast for my liking.
    Jul 2012
    Griffith NSW
    435
    My school didnt have the funds to justify buying a 1/4in slotting drill for one project, so we used a 1/4in router bit, with a 1/4in shank. The slot we cut was 200mm long in a 6mm thick strip of aluminium. Worked a treat, no damage to the bit and the job came out fine. It liked being spun fast, and some WD40 helped a great deal too, but thats nothing unremarkable for alu.
    Nov 2010
    Gippsland Victoria
    733
    Default Okay - will have a go
    Thanks for the tips.
    Will have a go.
    Bill
