Results 1 to 6 of 6
Thread: Rolling copper
23rd Oct 2013, 02:03 PM #1Intermediate Member
- May 2007
- Deception Bay / Brisbane
- 38
Rolling copper
Help from someone who knows what they are doing please.
I am looking at sheet metal roller's and trying to determine what thickness copper they can roll. All the one's I looked at expressed the thickness they could bend when rolling mild steel.
When you double the thickness of the material you require four times the force (everything else being the same), but the tensile strength of copper is about half that of mild steel.
From this it looks like you can roll 1.5 times the thickness of copper instead of mild steel.
Now if someone who knows what they are doing can tell me where I went wrong please.
Dennis
24th Oct 2013, 10:44 AM #2Most Valued Member
- 4,255
24th Oct 2013, 11:42 AM #3Intermediate Member
- May 2007
- 38
Hi Eskimo
To the best of my knowledge both the mild steel and copper tensile strength figures I got were for the un-annealed state but I am way out of my depth here.
Dennis
25th Oct 2013, 06:53 AM #4Philomath in training
- 6,541
I make that to be roughly correct. To bend something you need to get the material to yield. Random numbers from the internet - yield of steel starts around 250Mpa, copper around 70Mpa. Stress in the outer layer of material is related to the thickness of the material cubed.
Taking the cube root of (250/70) is approximately 1.5.
So if you could roll 1mm steel in the rollers, you would expect to be able to roll 1.5mm copper.
However,
- Copper will work harden (get a higher tensile stress as it is manipulated), and
- Yields of grades of copper vary with composition and supplied condition
So while this is a reasonable rule of thumb, it may not always apply.
25th Oct 2013, 09:45 AM #5Intermediate Member
- May 2007
- 38
Thanks Michael
All I was after was a rule of thumb, probably should have said it.
Where I started from was rolling some 2.6mm thick copper for a boiler which means I would have to get a roller which would roll 1.6 mm of steel.
Starting to get too expensive for the limited use it would get so I will just go to a firm with the machines.
Dennis
27th Oct 2013, 05:15 PM #6Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
copper
what some one rolled you for your copper.
aaron
