Results 1 to 11 of 11
17th Oct 2013, 03:35 PM #1
Mini Mill owner who also have a Rotary Table
What Rotary Table did you purchase for your Mini Mill? Have you mounted a 3 or 4 jaw chuck to the Rotary Table? If so, what chuck and type did you mount (and how did you mount it?)
Jim
17th Oct 2013, 06:58 PM #2Senior Member
- Oct 2009
- Upwey VIC
- 186
Jim,
I have the H&F Toolmaster 100mm tilting rotary table, R0014 | TRT-4 Tilting Rotary Table | machineryhouse.com.au but it needed substantial work to make it tilt in a vertical plane ie I had to line bore and ream the base and the table castings on the lathe, and make up a new pivot pin to bring the pin and table face parallel with the mounting base.
The table mechanism seems fine, although it has a 36:1 ratio, which appears to be unusual.
Due to the vertical space limitations on the mini-mill, I decided to make up a very slim-line 4 jaw holding fixture for the rotary table, made from an old cast iron pulley with guide slots cut using an end mill and a No.6 woodruffe cutter, jaws machined from an old piece of steel, and 8mm clamping screws.
The fixture mounts on the rotary table using the supplied T-nuts, and is centre aligned on the table by a small circumferencial lip machined into the back of the cast iron base with a close fit to the rotary table face.
It works OK, is quite rigid, and has been used to cut the flutes in the tap and dovetail cutters detailed in other threads.
Pictures attached.
Andrew.
18th Oct 2013, 08:07 AM #3
Andrew thanks for the reply and for taking the time to post photos.
19th Oct 2013, 03:10 PM #4Diamond Member
- Sydney, NSW
- 1,249
Hi Jim,
I was looking at this one, from India off Ebay. Not currently for sale but they do come off and on the market.
NEW Mini Tilting Rotary Table 3" 75mm With Clamping KIT Milling Machine | eBay
Ben
20th Oct 2013, 01:20 PM #5
I ended up purchasing one of these. I have to work out how to attach a chuck to it now..........LOL I feel like just welding it on
20th Oct 2013, 01:43 PM #6Most Valued Member
Welding it on would make fitting the chuck to your lathe tricky
I've found it handy at times to be able to move the workpiece, "chuck and all" from the lathe to the rotary table and back. So you might want to see if you can make that work, cant help much as A. I dont know size chuck and mount the C6 uses. B. I dont know if that Rotary table is big enough(though even if its a 4" I'd think you could make it fit).
20th Oct 2013, 02:02 PM #7
Hi Jim,
A front mounting chuck is the easiest option, just 3 bolts and t-nuts. If that's not an option, then maybe am adaptor plate.
20th Oct 2013, 03:25 PM #8
If that is a 4"/100mm RT then I don't know if 100mm front mount chucks are available?
I have this 130mm front mount on my 6" Vertex RT.
C280 | K11 SERIES 3 Jaw Self Centring Lathe Chuck | machineryhouse.com.au
20th Oct 2013, 03:46 PM #9
Another option would be a Morse Taper mounted chuck, such as this one (providing that hole in the RT has a Morse Taper?)
20th Oct 2013, 03:57 PM #10Most Valued Member
21st Oct 2013, 12:30 PM #11
Thanks for the replies.
The RT is 4" with three (3) slots.
I have searched for front mounting chucks and have seen a few, but they are drilled for four (4) screws.
I have considered getting a 80mm three jaw off eBay for $80.00 and 'having a go at drilling right through it and countersinking the holes to match the RT' not sure how that would go. The other idea I've had was a backing plate of 100mm and that would leave me 10mm around the outside with the 80mm chuck. Not a lot of room having just 10mm to work with though.
Welding is looking good again
Which rotary table for your X2 Mill
By Big Shed in forum METALWORK GENERALReplies: 3Last Post: 1st Oct 2009, 08:39 AM -
Mini lathe/mill projects?
By neksmerj in forum METALWORK GENERALReplies: 7Last Post: 28th Feb 2009, 01:47 PM -
Clamp Kit for X2 Mini Mill/Drill
By Big Shed in forum METALWORK GENERALReplies: 1Last Post: 26th Jan 2009, 08:53 PM
