Results 1 to 10 of 10
Thread: Evap O Rust
7th Oct 2013, 05:41 PM #1
Evap O Rust
I went to a garage sale on Saturday (golly my area had so many!!!) and I was there before the sparrows broke wind and scored a trailer load of fantastic tooling from an old bloke who had passed aways deceased estate. He had worked at BHP at Wollongong for 50 years the son said that was selling everything and the son was down for the weekend to move everything out, he's a software engineer and doesn't like tools and just wanted it all gone.....I obliged for the princely sum of $50.00
Everyday this old bloke worked in those 50 years, when he knocked off, he must have really KNOCKED OFF!!!! He must have left with every pocket full and his lunch box full as well every single day to accumulate what he did.
I'm not kidding, I have virtually a trailer load of P&N EVERYTHING!!! It's all old Aussie steel and lots have the Dept of Defense mark as well.......for $50.00 it's one of those mornings that I'll talk and remember for the rest of my life!
Some of it is a little rusty, nothing bad at all, but I don't fancy spending the next two years cleaning it up one at a time, so I finally bit the bullet and bought 5 Litres of Evap O Rust.
Has anyone ever used it before? Any hints? If I use it in an ice cream container, can I soak items in it overnight, remove them and then add more items into the same liquid? Will it be as effective not being fresh?
7th Oct 2013, 05:49 PM #2
Good work on that pickup i have some PN turning chisels and love them. Evaporation is my go to solution for cleaning up old tools. I soak them overnight depending how bad the rust is sometimes days. Then I use some steel wool to clean up the gunk and rinse under water. I strain the used liquid and place rare earth magnet in container yo pickup any excess metal and then good to go the next time.
I swear by it and has worked everyome for me. Great Aussie product
7th Oct 2013, 06:09 PM #3Most Valued Member
- Jun 2012
- SA
- 1,649
The worst that can happen is you will fail.
But at least you tried.
7th Oct 2013, 08:06 PM #4
EvapOrust
Hi Jim,
I have used the product. It's great stuff. I have left rusty stuff in it for a week at a time to remove deeper rust, as an experiment. I don't recommend that though. It is really good for light rust. For heavy pitting I'd recommend a wire brush or similar first. This is because it cost me $70 for 5 litres and using it to remove heavy rust is not the most economic idea. Unless the item I am removing the rust on does not allow me physical access due to it's shape, etc.
Be aware that it will lift chrome plating and hot dip galvanising if there is rust coming through or under the chrome or gal.
I have spoken to the importer and he tells me that if you want to dissolve rust from vertical panels you can create a three sided pocket with a piece of plastic and duct tape , trap some absorbent paper or the like between the plastic and the panel and then fill the pocket with enough evap o rust to keep the paper wet. He has sold quite a bit of this into the Coal Seam Gas industry as apparently the gas is quite corrosive when it comes out of he ground.
It goes pretty murky when it is spent and you can sort of tell it is not doing much at that stage. It does slow down as the chemistry is used up. Some items can take a couple of days to remove all the rust, so some patience is required.
The Beryl Bloke
7th Oct 2013, 08:25 PM #5
Be careful
Jim
Be very careful --------- don't get any of that stuff on yourself, you will dissappear forever
8th Oct 2013, 09:02 AM #6Most Valued Member
- 4,258
9th Oct 2013, 01:41 PM #7Novice
- Normanhurst NSW 2076
- 81
- 16
EvapOrust.
Dont use in metal container is my only advice. Otherwise it is excellent for light/moderate rust removal. Wirebrush/steel wool for heavier deposits.
Wash with warm water to clean off and dry. Drillit.
13th Oct 2013, 07:49 AM #8
Received my 5 litres on Friday by courier and was using it yesterday.
So far I have discovered that for best results its best to clean the objects in boiling water first to get all traces of oil and grease off for the stuff to do its magic.
13th Oct 2013, 04:33 PM #9
Black steel
I have not tried boiling water to clean anything with.
Just a note to let you know some steel will take on a permanent black colour after being in the Evap o rust. Seems to be a spring steel behaviour. The only down side to this is if the tool's size is printed on with black ink. You can't read the size afterwards. Somethings, like spring loaded calipers, can look really good with some black parts.
Th Beryl Bloke
13th Oct 2013, 05:24 PM #10Intermediate Member
- 93
- 45
Many thanks to all you coves for this very interesting thread, Bill.
Rust removal Evapo-Rust
By neksmerj in forum METALWORK GENERALReplies: 7Last Post: 22nd Jul 2012, 01:26 AM -
DAM Rust....
By Nurgle in forum METALWORK GENERALReplies: 24Last Post: 9th Oct 2011, 05:17 PM -
rust
By billym in forum METALWORK GENERALReplies: 4Last Post: 6th Nov 2008, 07:18 AM
