Results 16 to 30 of 110
Thread: Cern
26th Sep 2013, 06:24 PM #16
Probably left by a visiting Japanese engineer , the metrology stuff is a bit less euro-centric.. they even have a HP laser interferometer..
The whole metrology area is temperature controlled to 20C
2013_CERN_WKSHOP 087 (Large).jpg2013_CERN_WKSHOP 085 (Large).jpg2013_CERN_WKSHOP 083 (Large).jpg
They have a class 1 room, which has a seperate outer room for the operator
X ray scanner for checking welds.
A lot of the stuff they make is used at liquid helium temperatures, and high vacuum. They make their own
stainless steel bellows and cryo fittings.
2013_CERN_WKSHOP 094 (Large).jpg2013_CERN_WKSHOP 097 (Large).jpg2013_CERN_WKSHOP 100 (Large).jpg
This flexible stainless coupling is made up of rings of stainless and then manually tig welded.. one ring at a time.
A lot of difficult to weld parts are electron beam welded.
2013_CERN_WKSHOP 114 (Large).jpg2013_CERN_WKSHOP 115 (Large).jpg2013_CERN_WKSHOP 116 (Large).jpg
2013_CERN_WKSHOP 098 (Large).jpg2013_CERN_WKSHOP 111 (Large).jpg2013_CERN_WKSHOP 112 (Large).jpg
The last picture show a test piece indication the weld penetration vs the surface blow back, a lot of the
electron beam welding is difficult to weld stuff like copper.
That's it!
26th Sep 2013, 06:48 PM #17
On the CNC vs Manual question, I think its mostly CNC, but the manual machines are still used every so often, in specific instances they can handle much larger parts on their manual machines, like that big planer/mill in earlier pictures.
They are inclined to outsource jobs that involve a lot of repetition, or are "run of the mill" type jobs, and they seem to go for the really specialized hard to do type of work... lots of x-ray'ing of welds and testing of parts to make sure they are going to be vacuum tight and work at liquid helium temperatures...
Amazingly skilled people and amazing place.
26th Sep 2013, 07:20 PM #18Banned
- Jul 2011
- Melbourne Australia
- 1,376
The thing in the spindle is a Spindle Taper Cleaner. Normally they are timber or plastic with strips of Chamois leather attached.
Ensure Absolute Cleanliness of Spindles - Spindle Cleaners - BIG Kaiser
They are just being extremely Swiss, by leaving it in the spindle socket so dust doesn't get in there.
Regards Phil.
26th Sep 2013, 07:37 PM #19Most Valued Member
Nice.
I think my shed needs cleaning. Do you think they sweep their floors with a broom, or just use a feather duster?
I'd hate to pick up the tab on some of the stuff they make and do!
27th Sep 2013, 10:47 AM #20.
- 6,459
Truly wonderful Ray. I reckon it's like being a six year old opening presents on Christmas Day when you encounter machines and equipment such as you have seen.
I would have been happy enough to have spent a day just in the Atelier Mecanique.
Fantastique!
BT
27th Sep 2013, 05:11 PM #21
Hi BT,
You're spot on, like a kid in a candy shop it's all a bit overwhelming, almost defies description..
Google has just released streetview of CERN, including a section of the underground ring, and the ATLAS detector.
Google Street View Lets You Take A Virtual Tour Of CERN | Fast Company | Business + Innovation
I've only got the link, so I'm not yet sure how to get streetview underground... If someone figures it out let us know.
Last couple of days we've seen the Computing Center, ( and witnessed a little bit of History.. ) and got a look at an interesting experiment to see if gravity affects anti-matter the same as matter...
27th Sep 2013, 05:23 PM #22Most Valued Member
Hi Ray,
I couldnt get it to work from your link, just pictures.
This one seems to work.
https://www.google.com/maps/views/streetview/cern?gl=us
27th Sep 2013, 05:59 PM #23
3rd Oct 2013, 02:25 PM #24Golden Member
- Oct 2012
- Australia
- 621
Some of my Pic's
Adding some of my pictures into the mix.
Highres
There are some very nice rocks all over CERN, with a high density in the workshops, here is a nice 4x4' Swiss one.
Highres
Large Deckel Machining centre DMU 210 FD.
Highres
High precision CNC Lathe
Highres
Sample of one of their current work pieces, Combination of Lathe, Mill, and EDM.
Highres
Planer
Highres
The Crossrail flaking on the above planer.
3rd Oct 2013, 02:36 PM #25Golden Member
- Oct 2012
- Australia
- 621
Highres
Nice Collet Bed Mill.
Highres
Yet Another Swiss delight
Highres
A Cheeky FP2 just sitting outside the EDM section, Perfect condition
Highres
A well used Schaublin 160
Highres
A nice little drill press.
Highres
The Swiss being really Swiss
Still more to come
3rd Oct 2013, 02:54 PM #26Golden Member
- Oct 2012
- Australia
- 621
HighRes
A Machine very close to my interest; an in service Deckel FP2LB.
HighRes
Interestingly it had pull dials ?? Which means the FP2LB was still being produced along side its very very close relative the FP3L.
HighRes
Name Plate, It must have been very close to the last of these to be produced.
HighRes
Just another angle.
HighRes
And another
Yet still more to come
3rd Oct 2013, 03:04 PM #27Golden Member
- Oct 2012
- Australia
- 621
On to the Meteorology Shop.
Highres
Highres
Highres
Highres
Highres
Flexible vacuum coupling, it is TIG welded on the inside and outside. The are used all over their accelerators.
Highres
Finger for scale
Highres
Yet another nice drill press
Yet Still More
3rd Oct 2013, 03:13 PM #28Golden Member
- Oct 2012
- Australia
- 621
Highres
A nice little aciera
Highres
another shot.
Highres
Another Deckel FP3 in the corner of the sheet metal shop
Thats the end of my stills of the workshop but I have a time lapse video I will upload soon.
Next I will post some pics from the CLIC accelerator.
Highres
Dosimeters are fun....
3rd Oct 2013, 03:26 PM #29Most Valued Member
Hi Josh,
Thanks for the pictures.
Even at Cern the plates get used as coffee tables? or is that cup half full of Antimatter or some such?
To those that know about these things. Isn't that an awful lot of flaking on that crossrail?(but then one assumes that the person that put it there knew what they were doing........)
3rd Oct 2013, 04:11 PM #30Golden Member
- Oct 2012
- Australia
- 621
Yeah, but they have so many rocks and they keep everything so very clean.
On the scraping they are not in the habit of throwing out older gear in blind preference to modern cnc machines, which I like, it seems they would rather get their machines refurbished as soon as they wonder outside their required spec, every single machine they had in their workshop was in fantastic working condition.
