Results 16 to 23 of 23
26th Sep 2013, 02:48 PM #16Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,836
one of the ebay sellers got back to me and said the below bender will work with my aluminium sheet but its pricey i wish that youtube guy had a link to plans and material needed so i could go order it
Bending Brake 30" Sheet Metal Steel Heavy Duty Bender NEW | eBay
26th Sep 2013, 03:07 PM #17Most Valued Member
Not that pricey really(if it will do the job).
The utube guy doesn't say what thickness he used but you would pretty much need 3off 1m lengths of 100 x 100 angle. The place I buy from charges
$27.29(+$3.3 a cut) per m for 6mm
$35.15(+$3.3 a cut) per m for 8mm
$42.30(+$3.3 a cut) per m for 10mm
+ a couple of bolts + a gate hinge
Now if you have a scrap dealer about you might be able to get it cheaper.
26th Sep 2013, 03:35 PM #18Most Valued Member
- Aug 2009
- 1,836
awesome thanks , will these hinges work?
Hinge Weld Small Zenith Gal Rh Cd2 Har4103 I/N 4150060 | Bunnings Warehouse
26th Sep 2013, 03:40 PM #19Most Valued Member
They certain look like the ones.
He says it will fold 950mm wide. So it would be 950mm+two hinges you need. (I did say "pretty much a meter lol)
26th Sep 2013, 03:50 PM #20Most Valued Member
- Aug 2009
- 1,836
26th Sep 2013, 07:30 PM #21Most Valued Member
Hi Michael,
I Had been meaning to reply to your offer. I certainly would be interested in looking at a few pics of your folder. No rush, anytime you get a chance. I have some real heavy gauge steel 20mm and 40mm thick and now have a means of cutting it. A sheet folder seems like as good a project for it as any!
27th Sep 2013, 05:09 PM #22Most Valued Member
- Aug 2009
- 1,836
i built a sheet metal bender similar to that on youtube total cost was $53 but my building skills suck and i over cut sections so no close up pictures lol
but i can say it bloody worked!!!!!!!! i couldnt be bothered chopping off a nice new sheet to test on the bender so i quickly grabbed some scrap ive been practicing welding on its 1.6mm 5005 aluminium 25cm long and it only took around 2kg's of force to bend the sheet
i over bent the sheet but its scrap anyway, tomorrow ill cut out and bend a nice live bait tank hopefully it works out
one down side is my measuring skills suck i wanted to make my live bait tank 60cm long i now made the bender to small and its max bending with is 47cm that'll have to do lol
28th Sep 2013, 11:41 AM #23Most Valued Member
- Aug 2009
- 1,836
well guys my bending is almost done i just need to bend a couple of ends
check out the bends, that guy on youtube is awesome
took around 5-6kg to make the large bends and a little more force for the smaller bends all up the total area bent is 46cm long not bad saves a heck of a lot of welding
DIY Sheet Bender ?
By beer4all in forum TRAILERS & OTHER FABRICATED STUFFReplies: 11Last Post: 14th May 2013, 09:42 PM -
sheet metal job
By azzrock in forum METALWORK GENERALReplies: 0Last Post: 27th Nov 2011, 04:17 AM -
Metal work bender
By Grahame Collins in forum METALWORK GENERALReplies: 3Last Post: 12th May 2010, 07:04 PM -
3-in-1 Sheet Metal Machines
By grunto in forum METALWORK GENERALReplies: 6Last Post: 10th Jun 2009, 08:02 AM -
Rod Bender Plans
By chemworldx in forum METALWORK GENERALReplies: 4Last Post: 24th Oct 2007, 01:11 PM
