Results 16 to 22 of 22
Thread: tool to remove a 'fitting'
8th Sep 2013, 09:16 AM #16Most Valued Member
- 70
- 1,511
17mm tube spanner shimmed on two flats.
Nev.
8th Sep 2013, 12:52 PM #17Golden Member
- Jun 2005
- Helensburgh
- 618
Others who have described the procedure on the net do not seem to have needed any special tools, one stated that he just used an open end spanner. Cutting a socket might mean the socket walls will expand due to lack of support, an impact socket would be better if it will fit as the walls are far thicker.
CHRIS
8th Sep 2013, 08:20 PM #18Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,277
I can't see how you could use an open ended spanner, as I tried that first. There is simply not enough room to gain enough purchase to undo it. I got about 1/8 of a turn and that's it....
Maybe others found the fitting came loose after it moved that much. The one I did get undone ( it took some damage doing it ) took a full turn before it could be turned by fingers alone.
I agree, cutting a socket might allow it to expand unless I cut just enough out to get purchase.......
An impact socket may not fit due to the wall thickness....
I made some 1mm shims today and bought another 17 mm socket, so will try it tomorrow.
8th Sep 2013, 10:01 PM #19Most Valued Member
- Sep 2010
- Lebrina
- 1,910
If it were me, I would simply shape a suitable piece of 10 or 12mm flat bar into a spanner, drill a 17mm hole and then build up two flats with a welder in the appropriate places and finish them with either a file or a die grinder. If you can't use a spanner type piece due to space then weld a this piece as described onto the end of a socket. Job done. You could even use a suitable open end spanner, ground to achieve clearances with the end closed in for strength.
9th Sep 2013, 08:30 PM #20Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,277
All done.....
I've done this job and the tool worked well.
I glued ( so I didn't damage the socket with heat and because it was quick. ) in two 1 mm shims inside a 17 mm socket.
Very snug fit and it needed to be. One of the fittings was very tight.
9th Sep 2013, 08:38 PM #21Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Well done Steve.
A tricky one solved relatively easily
Phil
9th Sep 2013, 09:03 PM #22Most Valued Member
- Sep 2010
- Lebrina
- 1,910
Good job.
New member looking for appropriate tool/fitting
By fearlessflier in forum METALWORK GENERALReplies: 30Last Post: 17th Dec 2011, 06:52 AM
