Results 16 to 20 of 20
Thread: Douglas shaper ratchet
3rd Sep 2013, 10:13 PM #16Intermediate Member
- Dec 2011
- North Rocks
- 45
Hi Ewan
Thank you very much, and a bit of a master class too.
James
Sent from my iPad using Tapatalk HD
4th Sep 2013, 06:54 AM #17Most Valued Member
- Sep 2011
- Ballarat
- 3,103
I had the same thought Jordan, It would certainly be handy and probably doable (if that's a word) for me as I need a new pawl as well
Apparently the previous owners took the lower limiting stop off it Ewan and engaged quick traverse which promptly picked up over a ton of milling machine and spun it on it's axis.
That would've been interesting to watch
Phil
4th Sep 2013, 08:54 AM #18Golden Member
- Jun 2004
- Kyabram. Vic
- 632
Phil, I am guessing that it also left a brown stain in their trousers.
One of the things missing on this machine is the lower operator adjustable limit switch, pinned one is still there; but not much use when the leadscrew makes impact 6" prior. In this case nearly 2.4 tonne at a guess and the casting was the weakest link. Much weaker after the 2 bronzed repairs.
Ken
4th Sep 2013, 10:09 AM #19Intermediate Member
- Qld
- 44
Yes please
Hello Ewan,
I'd be interested in one too please.
With all this interest, you may have to set up a factory... )
K.
19th Sep 2013, 12:23 PM #20
Sorry guys.....the gears are still on my bench. I could make a poor excuse but really I've just been slack. I picked up some satchels yesterday and should be able to get them away this arvo.
Kraehe, if there is more interest I will do another batch, I only did 4 as that was all the steel I had of the right size, short of machining down much bigger bar.
Shaper table feed ratchet
By Ueee in forum METALWORK GENERALReplies: 10Last Post: 7th Jun 2012, 02:27 AM -
Douglas Shaper
By lamestllama in forum METALWORK GENERALReplies: 41Last Post: 1st Mar 2012, 01:13 AM
