Results 1 to 8 of 8
    Sep 2006
    South Coast of New South Wales Australia
    296
    Default Anyone have any experience casting brass?
    I have unlimited access to brass scrap. What I'd like to do with it is pour some castings to end up with brass cylinders around 12-14 inches long by 4 inch diameter.
    Anyone know how one goes about this?
    Jun 2012
    SA
    1,649
    Quote Originally Posted by Jim Ferrous View Post
    I tried melting brass and it was a failure.
    While my crude backyard furnace does aluminium OK, brass takes a LOT more heat to melt, so you need a good setup to melt it.
    Also I believe it gives off particularly nasty gases, so better read up on the safety side.
    Rob
    Dec 2007
    1,628
    Brass cylinders would be relatively easy in terms of ramming up your flask, and patterns, you will need to make core boxes so you have cores if you want the cylinders hollow.
    Where are you located??
    Jun 2008
    Victoria, Australia
    74
    5,080
    I've done a bit, you will need a furnace, crucible, pattern, petrobond, crucible handling equipment, safety gear etc....
    You can get away with a normally aspirated gas burner. But a forced air burner is better.
    A good starting point is to read up in the foundry area of the forum. I wrote up a bit of an introductory blurb http://www.woodworkforums.com/attach...casting101.pdf
    Recycling brass and bronze scrap is good fun, and whenever we do a bronze pour, I try to remember to prepare a few cylindrical blanks as stock for the lathe.
    Sep 2006
    296
    Thanks for the info.
    I'm still interested in doing this, my two sons are plumbers and scrap brass in 'on tap' so to speak in virtually unlimited quantities and the price of brass bar stock is very dear so pouring brass round stock looks super appealing to me.
    Just not sure if it's out of my league, I've been watching a ton of uTube videos and reading up as much as I can find on the web about it.
    Aug 2011
    4,779
    Hi there,
    If you have virtually unlimited access to scrap brass, you would be mad not to do the homework and set yourself up a nice foundry!
    Feb 2013
    Laidley, SE Qld
    1,038
    I'm casting aluminium using all online knowledge, ie making an LPG burner, making a furnace, mixing the sand, making a crucible etc.
    Metalcasting forums
    Quite a few Australians are members, there may be someone local to you who can guide your endeavours.
    Sep 2006
    296
    Not 100% sure what the actual brass tap bodies are made of, but the spindles and handles look like 'normal' brass.
  1. VICTORIA Brass Flat Bar Assorted Sizes & 1/4" SWB Threaded Rod & 260 Carbide Brass Sheet
    By thumbsucker in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 18th Mar 2013, 03:36 PM
  2. Casting about for cast iron casting ideas
    By Graziano in forum THE FOUNDRY
    Last Post: 1st Apr 2012, 12:05 PM
  3. Casting a brass nut.
    By Skew ChiDAMN!! in forum METALWORK GENERAL
    Last Post: 21st Nov 2011, 01:04 PM
