Results 16 to 30 of 39
  1. #16
    Jun 2005
    Helensburgh
    618
    My Servian. I found it in the back of a workshop many years ago and paid about $150 for it. It is a four speed gear head drive which limits the top speed a bit but for the price I didn't complain. I think Servian were a bit like the Asian importers today, that is they sourced a drill and re-badged it. I know of another like mine the only difference is it has a two speed motor thus eight speeds.
    CHRIS
  2. #17
    Jun 2008
    Victoria, Australia
    74
    5,080
    Quote Originally Posted by Chris Parks View Post
    That looks like an Arboga? I guess Servian rebadged it. Either way it's a top of the line machine!
    I've seen a few Australian made Servian's they are every bit as good as the Waldown's originally made in Melbourne, but obviously that one is a badge engineered version.
  3. #18
    Jun 2005
    Helensburgh
    618
    My toolmaker BIL offered me a lot of money for it the first time he saw it. i declined! I dislike the round table and the fact that the table does not tilt but some things are worth tolerating.
    CHRIS
  4. #19
    Jul 2006
    Athelstone, SA 5076
    4,258
    For really small holes they did a 12,000rpm version - rarer but still in demand at the right price.
    AND Dont forget Guys...i need a spindle etc for the one I have!!!
    speaking of which...did they use common parts....ie would another model's spindle fit?....brobo didnt say when they advised that parts were not available...so I am guessing the answer is No
  5. #20
    Oct 2004
    Southern Highlands NSW
    1,898
    I think an adjustable split quill housing feature is over-rated. It can't compensate for an unevenly worn quill.
    I'm not too familiar with different ways of designing the spindle/quill. This is how it is on my Walker-Turner.
    Jordan
  6. #21
    Oct 2004
    1,898
    Having a table that maintained alignment when being raised or lowered would be a blessing.
    I should have been clearer about what I meant about sloppy rack & pinion, Bob. The bevel gear system is an improvement in that it avoids the tilting effect of the rack at extremes of vertical travel, when moving the table around the column. But it doesn't maintain position when loosened.
    Jordan
  7. #22
    Charlestown NSW
    65
    1,673
    Perhaps a few others can add their Waldown stories or of other brands worth the effort of restoring.
    The old Aussie made Richardson are a good machine as well. Came in a variety of flavours as bench or floor models, morse taper spindles, or direct mount spindles. various drive configurations.
    I posted some pics of the circular table I fabricated for mine in this thread http://www.woodworkforums.com/f65/ri...8/#post1639672
    If your budget doesn't run to a Waldon then a Richardson would be well worth considering. There used to be lots of them around.
    regards
    bollie7
  8. #23
    Aug 2011
    4,779
    My Tough has a direct mount chuck Jordan. If it didn't the chuck would dangle from the end of a 2 Morse quill extension. When I used to religiously check the Reliable Tools site on Ebay, there would frequently be Walker Turners listed. Nice looking bits of gear. Then after tiring of looking at one porch paint job after another I lost my religion. Having a table that maintained alignment when being raised or lowered would be a blessing. I suppose it's why they came up will mill drills.
    I would have to be Merlin for that sort of transformation. The unmolested table was bought new from Brobo Waldown. I think this is what you remember - http://www.woodworkforums.com/attach...018-large-.jpg
    Bob.
    I C said the blind man. That new table does look like the sort of transformation you are capable of though Bob!
    A bit disappointing from someone like you but I will let it slide.... on this occasion.
  9. #24
    May 2010
    135
    Default what is the drill I'm describing?
    There is a drill press where the column is capped with a T junction,a nd a horizintal pipe (similar diameter to the column) goes across the top (like a letter T) with the quill at one end of the horizontal, and the motor at the other. I believe the horizontal pipe is used to adjust the throat of the drill.
    Does anyone know what that type/ brand of drill is? - My Dad is looking for one.
    Thanks,
    Des
  10. #25
    Jun 2008
    Victoria, Australia
    74
    5,080
    Quote Originally Posted by desbromilow View Post
    Thanks,
    Des
    Hi Des, That's a radial arm drill,
    Here's a google image search https://www.google.com.au/search?q=r...w=1600&bih=966
    PS Someone on here had a Waldown radial arm drill, I think with rotating head as well?
    Ok found it!
  11. #26
    Jan 2004
    Towradgi
    95
    Quote Originally Posted by Oldneweng View Post
    Having another look the following one has a good description and plenty of photos. Waldown Drill Press in Illawarra, NSW | eBay This one sounds like it would be fine for me except for its location and it is only a bench model. It has a top speed of 5500rpm . Wow.
    Around the corner from me, interesting, maybe a mate for the Fidax bench drill in the old shed . . . or pick up for someone else interested.
    Pat
    Work is a necessary evil to be avoided. Mark Twain
  12. #27
    Dec 2011
    Sydney
    505
    Des,
    On the ones I recall, you could adjust the head to give a very large throat, and also rotate the horizontal bar supporting the head to drill holes at an angle to a horizontal table. I think they used to be made by Parken, and marketed to pattern makers, and was astonished to find they are still in business (Parken Engineering) making very well specified floor and bench drills (hard chrome column, anyone?).
    Back on the Waldown theme the attached photo shows a rather laid back version spotted recently at Mick Moyle's.
    A wall mounted Waldown? (Only because I haven't worked out how to rotate the image.)
    Bill
  13. #28
    Jan 2004
    Mackay North Qld
    6,446
    I want a pedestal drill as mentioned, but I am not going to be able to survive without a table lifting Mech.
    Dean ,
    I am Kevin Grahame from Queensland and here to help
    The table can be counter weighted to overcome sans rack.Does this fine example of past Aus engineering have a hollow column? Its neat and tidy to have the counter weight run up and down inside the hollow tube but there is an alternate .I have the hollow column set up on my old Taiwanese DP.Its a few seconds work to do a table height change ans smooth as silk..all you need is to turn a couple of pulleys and buy some 3mm wire rope and clamp fittings.
    It is still possible to run the counterweight say in a piece of PVC tube mounted vertically Parallel to your column.
    If you would like further details ,please indicate and I'll hunt out the diagrams /photos.
    in Mackay where no such gems are to be had
  14. #29
    May 2010
    135
    Thanks ray!!!
    I'm used to radial arm drills being the big industrial type with a cast arm resembling a slide, with the motor and quill as one piece.
    Grizzly Industrial - G7945 Radial-Arm Drill Press - Fine Woodworking Tool Review
    and the link you found are the type I'm chasing for my dad - THANKS!!!
    Des
    Ok found it!
  15. #30
    Jan 2011
    Far West Wimmera
    63
    4,049
    Dean ,
    Thanks for the reminder Grahame. I remember reading a post that mentioned this and I then looked it up on the web. At the time was not overly impressed because I had a rack and pinion system but on an drill without lift it would be a way around this.
    A few different drills mentioned now. Keep it up guys.
    Just one other point tho. If there is something you feel limits your drill or something that adds extra ability to it, open right up so anyone looking to buy one can keep these ideas in mind.
    Chris.
    What is it about the round table that you don't like?
  1. Waldown Hispeed bench drill
    By RJT in forum METALWORK GENERAL
    Last Post: 29th Sep 2012, 10:06 AM
  2. Waldown Radial Arm Drill makeover
    By richo132 in forum METALWORK GENERAL
    Last Post: 7th May 2012, 10:26 PM
  3. Waldown Drill Press
    By KevM in forum METALWORK GENERAL
    Last Post: 1st Sep 2011, 01:31 AM
