Results 31 to 39 of 39
19th Aug 2013, 08:43 PM #31Diamond Member
- Sydney, NSW
- 1,249
20th Aug 2013, 12:20 AM #32Golden Member
- Jun 2005
- Helensburgh
- 618
Most square tables have hold down slots where this one does not. That combined with no tilt makes stuff a bit hard some times. On the other hand the head has rise and fall and both it and the table rotate around the column. I have used this in times past to end drill columns etc. I suspect if I got into the motor I could make it two speed but I can't be bothered.
CHRIS
21st Aug 2013, 11:08 AM #33Banned
- Jul 2011
- Melbourne Australia
- 1,376
G'day Bill.
Its pretty common to see that configuration in repetition turning shops. Its set up to put the chamfer on the ends of bars, so they run through the bar feeder and into the spindle. You put a female cone in the spindle that has a blade that shaves a large chamfer. The chuck is to clamp the bar. Normally a 3 jaw, self centering, looks to me like that one is a 4 jaw.
Regards Phil.
On edit, That seems to be a 4 jaw self centering scroll chuck. I guess that would be good for square bars also.
21st Aug 2013, 07:00 PM #34
Ok Chris. My round table has 6 hold down slots (not Tee), rotates on its own axis, rotates around the column, tilts left and right and has a thru hole in the centre about 20mm diam. I have also fitted an angle bracket underneath it to clamp a length of 25mm RHS as a support for long pieces. If it had precise 90 deg locking on all pivots it would be the perfect table for me.
23rd Aug 2013, 11:00 AM #35Most Valued Member
- 4,258
20th Oct 2013, 09:02 AM #36Philomath in training
- 6,562
Dean popped in to visit last night and try out the Waldown. He also tried an Albrecht chuck. I think we have another convert...
20th Oct 2013, 09:52 PM #37
19th May 2021, 05:17 PM #38Member
- Apr 2013
- Canberra
- 54
19th May 2021, 06:21 PM #39
as you say,there must be something special about them, Michael.
They were installed in the Man Arts section at the school I last worked at .
If exposed to high school kids and surviving after 30 plus years, that is enough to recommend them on the grounds toughness and reliability.
It would be nice to see one tricked out with good bearings, keyless chuck and good lighting.
I have a soft spot for them.
Waldown Hispeed bench drill
By RJT in forum METALWORK GENERALReplies: 6Last Post: 29th Sep 2012, 10:06 AM -
Waldown Radial Arm Drill makeover
By richo132 in forum METALWORK GENERALReplies: 10Last Post: 7th May 2012, 10:26 PM -
Waldown Drill Press
By KevM in forum METALWORK GENERALReplies: 24Last Post: 1st Sep 2011, 01:31 AM
