Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    Nov 2007
    melbourne australia
    3,228
    Default What to do with this piston?
    Gents,
    A friend gave me this piston out of a ship's engine. He has sandblasted it clean so it has a nice satin finish. Bore is 125mm.
    I'd like to put it to use in the workshop somehow. I could take up smoking and use it as an ashtray, but that would be too easy. I thought about drilling a bunch of holes in the crown to hold small items like scribers, pencils, etc. Anyone got a more imaginative idea?
    Apr 2013
    adelaide
    293
    Default Mount it
    Mount it on a nice polished wooden stand and tell the wife you bought it for her to put on the mantelpiece.
    Nov 2007
    melbourne australia
    3,228
    Nah, we haven't got a mantlepiece.
    How about one of these in the gudgeon pin hole? Should be a perfect fit:
    49 50mm Japan Movement Premium Solid Brass Quartz Insert FIT UP | eBay
    Jan 2010
    Bundoora, Melbourne.
    212
    Put it in a ship's engine
    -Scott
    Jun 2012
    SA
    1,649
    Pistons are one of those things that are beautifully made, look good, inspire wonder, and are totally useless for any other purpose.
    I can't tell you how many times I've looked at old pistons and though these must be good for something.
    Nope. That's why someone gave it to you - they probably got sick of thinking what to do with it.
    Maybe turn it upside down and put your pencils and biros in it.
    Rob
    Jul 2012
    Griffith NSW
    435
    Ill be interested to see some good ideas on this, Ive got one as well. Its a little bigger in the bore and Ive got the conrod too. Whatever I end up doing with it, itd best to do it just once, its a bloody heavy unit!
    Jun 2012
    SA
    1,649
    The big piston affliction is only slightly worse than the big nut problem.
    You go into an office in a workshop and the guys got this humungous nut on his desk, shelf, cupboard, window sill - and it's always painted RED for some reason.
    Too heavy for a paper weight, too small for a door stop - totally useless again.
    So you say " my that's a mighty big nut you've got there".
    This is always followed by "you should have seen what it came off of ".
    yep.
    Seen this all before.
    If its big and free a blokes just got to have one.
    Rob
    May 2011
    Murray Bridge S Aust.
    72
    5,988
    I like Jack620 idea of putting a clock in the gudgeon pin hole, if you could find a nice piece of timber, polished and mount the piston on it.
    Should look pretty good.
    Jan 2011
    Far West Wimmera
    63
    4,049
    Small clock! Do for a desk or something like that. Rob's suggestion is the most common use I have seen them put to. Since I have been involved in making thousands of them my suggestion would be to melt it down and make something useful out of it!!
    Nov 2007
    melbourne australia
    3,228
    The gudgeon pin hole is 50mm, which is a reasonable sized clock. Here's an example.
    Jun 2007
    sydney ( st marys )
    65
    4,902
    Bad luck its only small, the larger ones make a good outdoor coffee table and seats.
    Nov 2007
    melbourne australia
    3,228
    The ship wasn't that big.
    May 2002
    in the outer reaches of Sth Oz
    75
    525
    melt it down and cast something useful?
    Boycott Shampoo!!
    Demand Real Poo!
    Jul 2013
    77
    Default Get
    Get someone to jewel it for you!
    It will still be totally useless, but it will look too good to throw out!
    Men, like Bower birds, love & collect shiny things!.
    If you could drill it with enough holes.... and fit it into a matching sized 125mm PVC Pipe - with matching holes- maybe you could make a compressed air blast gate out of it or something?
    Fill it with lead and use it as a counter weight on a sash chord over a pulley as a door self closer?
    CNC carve something around the outside of the skirt and fit LED's inside it and make it into a lamp.
  15. #15
    Aug 2007
    Saskatoon, Saskatchewan, Canada
    292
    Cut it in half from top to bottom and make book ends out of it. You can put still put little clocks in the holes too, set for two time zones, or standard and daylight savings time if you Aussies do the clock changing thing.
    Pete
  1. Drill powered piston shear
    By Bob38S in forum METALWORK GENERAL
    Last Post: 18th Oct 2006, 10:22 AM
