Results 1 to 15 of 15
Thread: Air Tool Operation
4th Aug 2013, 01:11 PM #1
Air Tool Operation
Having just received the new micro die grinder mentioned in .RC's thread http://www.woodworkforums.com/f65/an...dremel-173890/ I have again started thinking about how to operate my meager collection of air tools properly. The instructions that came with the die grinder consisted of pug it in, turn collar this way for on, that way for off and turn on slowly. That was it. It came with a plastic device that looked like an inline filter which on searching EBay (my Google for product information) I discovered that it was an inline oiler. I had that day bought a litre of oil for these tools. "Rocket" brand so I know they will go fast now.
I have done some searching on the net but had very little success with finding information on the proper setup and operation of air tools. The oiler that came with the grinder connects to the rear of the grinder itself which means that there is no extra oil passing thru the air lines. It does not appear to have any adjustment for flow. I presume that using this oiler means that I don't have to squirt oil into the tool every so often. Shame really cos they also supplied a nifty little bottle with a dripper nozzle that works great.
Can anyone point me to a good source of info about this matter and/or provide me with your knowledge and observations?
4th Aug 2013, 02:52 PM #2Most Valued Member
- Jun 2012
- SA
- 1,649
[QUOTE=Oldneweng;1680651
Dean[/QUOTE]
Hi Dean,
DO NOT use the clear plastic oiler that comes with the unit. These are totally useless, and seriously over oil it. They also leak oil everywhere when stored.
You can buy better quality adjustable ones if you want to go this way.
Instead, just use the little oil bottle you get and add a drop of oil into the connector at the rear of the tool every hour. That's all you need.
Use a light oil when the stuff supplied is used up - ATF works well.
Also make sure the air supply is dry. There should not be any moisture or condensate visible at the exhaust port of any air tools used.
I've had my CTC pencil die grinder at least 5 years and it's still as good as the day I got it. Dry air and a drop of oil are all it needs.
Rob
4th Aug 2013, 08:08 PM #3
Thanks Rob. I have not connected the oiler yet so will just leave it off. As I mentioned, extra oil from a permanant oiler at the compressor, being fed thru the air lines concerns me if I need to do spray painting. I have a moisture extractor at the compressor. I have just bought a litre bottle so this should last me for a loong time.
4th Aug 2013, 08:55 PM #4Most Valued Member
- Jun 2012
- SA
- 1,649
Hi Dean,
Yes, the last thing you want is oil (and moisture) going through your air lines.
It's unlikely you will be running any air tools continuously for hours on end anyway.
So a drop of oil directly into the connector every so often is more than enough to do the job.
A litre bottle of oil will last for several generations at least
Rob
4th Aug 2013, 10:10 PM #5
That is what I thought when I saw that only litre bottles were available. I went in with $10 expecting a little bottle, looked at the range starting at $32 and kept going down the line until the very last one was in my price range at $8. I was surprised to see so many choices for a small town shop.
4th Aug 2013, 11:08 PM #6Most Valued Member
- 70
- 1,514
Yeah, a drop or two of oil everytime you use it is ok. If you do decide to use an inline oiler (with a dedicated hose for use with it) I do have one of these - http://www.woodworkforums.com/f223/new-oil-lubricators-137647/#post1351664 - still sitting here doing nothing. Send me a PM if you want it.
Nev.
4th Aug 2013, 11:27 PM #7
When i worked as a cabinetmaker we used air tools all the time, mostly nail guns, sanders and drills, and then all the big machines that used air, wide belt sanders, hinge press, borers etc.
We never had inline oilers, except on the machines, down line from where they plugged in. A few drops in the tool in the morning, after smoko and lunch and that kept them running fine. We did have water traps, both built into the plumbing and on the regs. For spraying we used a car booth so it had its own oil and water traps, plus charcoal filters for air supply if we suited right up.
5th Aug 2013, 03:44 PM #8Most Valued Member
- Australia east coast
- 2,713
5th Aug 2013, 04:35 PM #9
5th Aug 2013, 05:23 PM #10Most Valued Member
- Jun 2012
- SA
- 1,649
Just a tad expensive
I hope no-one bought their air pencil die grinder from this bloke
KS Tools 515 3198 16 X 132mm 70000rpm AIR Pencil DIE Grinder | eBay
Exactly the same as my $30 (delivered) unit. There was someone in Germany trying this same thing when I bought mine.
Unreal.
Can't imagine anyone would buy one at that price.
EDIT*** It gets worse - check this out.
1 8" Micro AIR DIE Grinder Pencil Type 65000rpm Polishing Engraver Tool W Case | eBay
This one is the identical kit that I got from CTC.
Rob
5th Aug 2013, 05:48 PM #11Most Valued Member
- 70
- 1,514
5th Aug 2013, 06:24 PM #12
The fifty they have sold were at $18.95 would say they have run out as they increased the buy it now price on the third some of them (ebay sellers ) do that as the easy way to stop selling until they have more in stock instead of closing the item and relisting when they have more in stock
Cheers Rod
5th Aug 2013, 06:35 PM #13Most Valued Member
- 70
- 1,514
5th Aug 2013, 06:37 PM #14Most Valued Member
- Jun 2012
- SA
- 1,649
This is the CTC kit that I have:
MICRO AIR GRINDER #C99
If you google "micro die grinder" it's sad to see how many on line stores are trying to rip people off on these things.
$60 - 160 is quite common.
The exact same unit can easily be had off Ebay for less than $40 (delivered).
They are a tremendous little tool.
Rob
5th Aug 2013, 08:33 PM #15Most Valued Member
- 2,713
Stop for second chucking operation.
By localele in forum METALWORK GENERALReplies: 35Last Post: 11th Jun 2012, 10:36 PM -
Slitting Saw Operation
By electrosteam in forum METALWORK GENERALReplies: 16Last Post: 12th Jan 2010, 10:23 AM
