Results 1 to 12 of 12
Thread: I got a lathe!
1st Jul 2013, 04:09 PM #1Intermediate Member
- May 2013
- QLD
- 47
I got a lathe!
Hi, you may remember me from a few weeks ago asking all the anoying questions about lathes, well I have some more for you, because of how confused I was about the lathe I went down to hare and forbes with the intent of buying a al-50g but when I got there all became clear, the al-50g was flimsy and small so I stepped up a size, to the al-320g, well lets just say the budget was blown out of preposition and now I need to move it, but it will suet me a lot better.
So, I have an al-320g and have no idea how to clean the gear box witch, as I have seen a lot on here, is filled with sand and iron filings.
What do I do?!?
Any other tips on cleaning the lathe or getting it ready for use will be a big help, I would also love it if someone directed me to some good beginner sources for me about grinding tools and lathe brake in, I am determend (how do you spell that word?) to get this thing working for her maiden voyage.
Thanks so much for all your help.I tried to be good.
But the other options where better.
1st Jul 2013, 05:51 PM #2Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
nice one
hi mate ive seen one of these i think. not bad. it had a 40mm spindle bore
what are you going to do with it?
aaron.
1st Jul 2013, 06:47 PM #3Senior Member
- Jul 2012
- Griffith NSW
- 435
The hercus text book of turning (an old copy is kicking around these forums somewhere) is still almost entirely relevant to your machine and it has some excellent info for tool grinding, shapes and cutting speeds. Its an exceptionally handy book.
Congrats on the new machine!
1st Jul 2013, 07:11 PM #4Member
- Brisbane
Congratulations! You will have it for a long time I am sure.
There is no need to clean it out H&F is very fussy about quality so you won't find any sand in there. That was the advice I got when I bought my 320G lathe in January and everything I saw confirmed this was correct.
Grab yourself some kerosene and some rags, a paint brush and an ice cream container to pour the kero into, pull the tailstock apart, remove the crossslide and clean it all up and then oil it. H&F will sell you a 5 litre bottle of oil. I also disassembled the 3 jaw chuck to clean it. I had to do a bit of work on one of the jaws on the 4 jaw chuck as one was binding.
1st Jul 2013, 07:22 PM #5
Good
Well done
When I was your age, I was sticking plastic kits together LOL
Mike
1st Jul 2013, 08:43 PM #6I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,270
So THAT's where all the sand and various other shrapnel comes from... Sorry, I just cracked up when I read that, and I couldn't resist...
I'm not quite sure if this is sarcasm or not, but I can assure you my H&F AL335 had a good dose of grits right through it. The oils in the thing also appeared to be crude oil scraped straight up off the ground, which in hindsight would probably explain the grit...
Certainly worth a look in any new lathe out of China - to paraphrase Forest Gump, they're like a box of chocolates, you never know what you're going to get. Certain models do seem to better than others though...
1st Jul 2013, 09:02 PM #7Intermediate Member
- May 2013
- QLD
- 47
1st Jul 2013, 09:22 PM #8Senior Member
- Jul 2012
- Griffith NSW
- 435
I dont personally need it, ive got a set of ten sitting above my desk at work. Post it though, itll make looking for it easier for anybody else looking for some good info to start from.
1st Jul 2013, 10:14 PM #9Intermediate Member
- May 2013
- QLD
- 47
http://www.bbssystem.com/manuals/Lathe-Tutorial.pdf
Tell me if this doesn't work.I tried to be good.
2nd Jul 2013, 12:27 AM #10Senior Member
- Apr 2010
- ringwood vic
- 251
G'Day Young Fella,
RE : pulling the tailstock to bits, by all means remove the barrel to clean the threads, but bear in mind dismantling the side to side adjustment slides will require realigning the tailstock, which can be a bitch of a job for experienced players and could induce premature baldness in a newcomer.
Regards,
Martin
2nd Jul 2013, 12:52 AM #11Intermediate Member
- May 2013
- QLD
- 47
2nd Jul 2013, 08:57 AM #12
Obviously the lathe must be unplugged......
If there is sand in the gearbox (and there was none in my AL320G gearbox which was quite clean) then you need to drain the oil out (the drain plug is on the left of the gearbox, in the belt area) then take the top cover off. From memory you need to take the switch box off the top of the cover, leaving the wiring connected.
Once you have the top off you should be able to clean out the inside of the gearbox with rags and kerosene. Perhaps flush a bit of oil through the gearbox while the top is off to do the final cleanup. Use hydraulic oil, 32 or 46 weight.
When you put the top back on you might want to replace the gasket with liquid gasket rather than re-use the poor excuse for a gasket that comes with the lathe and seal the screw holes where the switch box is fixed to the top lid.
Finally, refill the gearbox to the level on the sight glass and check for leaks from the top cover once the lathe is restarted.
Any Atlas Lathe and Drummond Lathe Owners out there?
By j.ashburn in forum METALWORK GENERALReplies: 3Last Post: 8th Apr 2013, 06:22 PM -
By Auskart in forum METALWORK - Machinery, Equipment, MARKETReplies: 9Last Post: 29th Jun 2010, 07:02 PM -
