Results 1 to 15 of 37
27th Jun 2013, 08:21 PM #12-legged animal
- Jan 2008
- Murwillumbah Nthn NSW
- 69
- 118
put a hard point on a small bolt ?
G,day fellers , I need to put a hard point on a small bolt . Thought of hard facing the end and grinding it to a point but cant seem to find any hard facing rods smaller than 3.2 which is a bit big . Anyone got any ideas --- thanks ---Mat--
27th Jun 2013, 08:27 PM #2Most Valued Member
- Oct 2007
- 3,112
What is the intended use? I've case hardened the heads previously, but the case hardening is thin and I don't know if it would be thick enough, depending on what you mean by a "point". Why does it need to be hardened, and how much wear are you expecting?
Pete
27th Jun 2013, 08:29 PM #3Most Valued Member
- Jun 2012
- SA
- 1,649
27th Jun 2013, 09:27 PM #4
What about cherry red? case hardening compound...
You can get it from these guys Case Hardening Powder 250gram NON Toxic Made IN THE USA Suit MILD Steel | eBay
27th Jun 2013, 09:36 PM #5
What Rob said.
Drill a hole and insert a bit of drill shank.
SWK
27th Jun 2013, 10:00 PM #6Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
I believe drill shanks are soft. That's why they score when they spin and why you can file the knobs off. Couple of suggestions: Buy a high tensile bolt the right size and grind the end to a point. They are more tough than hard, but may do the job. Otherwise, make the bolt from a hardenable material and heat treat to taste, eg point hard, threads not so much.
27th Jun 2013, 10:29 PM #72-legged animal
- Jan 2008
- 69
- 118
thanks fellas
thanks fellas that gives me a few things to try till somthing works . Guess I,ll start with the easiest option [high tensile bolt] and work my way through the other options if it doest work .
The bolts screw into nuts welded onto brackets on a small electric SkillMill and stops the rails dropping from the required height . So the point screws in against gal mild steel square tube and stops the collar sliding down under probably 30k of weight on each side .
good night all
27th Jun 2013, 10:43 PM #8Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
27th Jun 2013, 11:19 PM #9Most Valued Member
- Sep 2011
- Ballarat
- 3,103
28th Jun 2013, 02:20 AM #10Intermediate Member
- Apr 2013
- San Diego
- 28
Consider using cone point set screws.
Gene
28th Jun 2013, 10:08 AM #11Most Valued Member
- 70
- 1,514
Another option I believe is Dog Point.
http://www.fasten.it/immagini_utenti/2969_19658.jpg
ALBERT PASVAHL GMBH & CO: Albert Pasvahl offers you their experience...
Nev.
28th Jun 2013, 11:13 AM #12
Hi Mat
You asked the wrong question, you should have asked how to stop a slipping collar.
What you need is something to increase the friction between the collar and the frame maybe a rubber block under the bolt, and a piece of flat steel to apply the force from the screw to the rubber pad.... which gives a larger surface area and more friction.
The pointed bolt will just dig in and cut into the Galvanized surface and eventually it will get chewed up and probably rust, since the gal will be scratched through..
A picture of the current set up will help, I'm sure there will be a better solution than a hardened pointed bolt...
28th Jun 2013, 01:46 PM #13Most Valued Member
- 70
- 1,514
Something like this with the Swivel Pad to go with it?
WDS 672 Swivel End Adjusting Screw, Hand Screws, Wing Screws, Thumb Nuts & More - WDS
Or maybe this?
WDS 674 Swivel Pad Type A - Steel Pad, Machine Feet - Levelling Feet - WDS
Lots of options there.
Nev.
28th Jun 2013, 05:47 PM #14Most Valued Member
- Jun 2012
- SA
- 1,649
I agree on the OP question bit - and that a pointed bolt is not the way to go.
But I have to disagree on the more surface area, the greater the friction - not so for a given force. Stays the same.
This is probably the only experiment I remember from skool days Oh, and burning out the see through OHM meters we had.
Look it up and you will see what I mean.
Rob
28th Jun 2013, 08:20 PM #152-legged animal
- Jan 2008
- 69
- 118
pointy bolts el-cheepo design
Yes I agree , pointed wing-bolts is one of a number of cheap and crappy design faults and probably why Peterson discontinued the SkillMill . The pointed wingnut bolts that screw in to stop the rail slipping get blunt and slip . Bought some grub screws 2day that are very hard - if they dont work I,ll have to consider changing the design as kindly suggested .
Not a big problem compared to the rest of the world - riots and wars etc . have a good night blokes ----mat--
oh and the missus is serching for our cameraLast edited by Mathuranatha; 28th Jun 2013 at 08:22 PM. Reason: forgot to add onr point
putting hard point on small bolt?
By Mathuranatha in forum WELDINGReplies: 1Last Post: 28th Jun 2013, 06:18 PM
