Results 31 to 37 of 37
30th Jun 2013, 10:37 AM #31Senior Member
- Newstead Victoria
- 459
Forgot to add Craft disease here [cant remember any thing'] its like climbing a rope those jacks but solid one grips the other releases bottom one bites allowing the upper to slip up then grip then the bottom does the slip up for the next lever stroke. John.
30th Jun 2013, 01:52 PM #322-legged animal
- Jan 2008
- Murwillumbah Nthn NSW
- 69
- 118
30th Jun 2013, 05:07 PM #33Most Valued Member
- Jun 2012
- SA
- 1,649
From Google images: From memory, the top lever lifts and the bottom lever lowers it.
Genius whoever thought it out - one of Hilter's secret weapons.
30th Jun 2013, 08:50 PM #34
30th Jun 2013, 08:54 PM #35
30th Jun 2013, 09:12 PM #36Member
- May 2012
- Oakleigh, Victoria
- 55
Back to the original question for a moment,
I've previously centre drilled the end of a bolt and pressed in a ball bearing for this purpose.
Ball can be retained with an interference fit or peening it in with a centre punch.
Back off topic again,
The really unfathomable thing with those VW jacks is that they eventually gum up and don't work properly, the cure is to oil them!
30th Jun 2013, 11:53 PM #37Most Valued Member
- Jun 2012
- SA
- 1,649
I never really trusted them (or any jack) because even though they wouldn't slip (I think the more weight you put on them the harder they gripped) they had a nasty habit of tilting off of vertical in the flimsy tin tube they fitted into with the car.
They also had this not very big round base that encouraged the tilting action.
I suppose you could say that the jacks were about as good as the brakes.
Unsafe at any speed.
Rob
putting hard point on small bolt?
By Mathuranatha in forum WELDINGReplies: 1Last Post: 28th Jun 2013, 06:18 PM
