Results 16 to 30 of 37
28th Jun 2013, 09:20 PM #16
Hi Rob, You are correct of course, I remember a high school physics experiment doing something similar.... the thing that jumped into mind, as soon as you mentioned it, was "what's the point of wide tyres on cars?" I still can't answer that question with any degree of satisfaction.... I google it, and not sure I agree with some of the answers... we need Stuart for a tricky one like this...
28th Jun 2013, 10:31 PM #172-legged animal
- Jan 2008
- Murwillumbah Nthn NSW
- 69
- 118
Well walking on a wet piece of mild steel sheet can be quite slipery but checkerplate or diamonmd plate mech , or even 2" arc mesh mesh or even flat sheet with blobs of weld stuck all over it all are a lot less slippery even though the "same material "[mild steel]
Thats why the pointy bolts work on the mill , untill they get blunt then they slip . Same with tyres - the same with tyres , the same rubber but those with sharpish lumps or ridges get more traction than bald smooth ones . A lot of the "science " I leared at school has now been replaced with new "theories '
28th Jun 2013, 10:38 PM #18Banned
- Jul 2011
- Melbourne Australia
- 1,376
28th Jun 2013, 10:59 PM #19
29th Jun 2013, 01:28 AM #20Most Valued Member
29th Jun 2013, 01:58 PM #21
Yes, both made of rubber...
Googling has lead me to a number of different answers and complications, but the bottom line is that friction is independant of area, however in the case of car tyres there are a lot of other factors involved, and race car tyres are run hot and sticky, so the tyres stick to the road, and it's more about adhesion than friction... also, Wider tyres give greater roll stability in cornering..
Back to the original question, the friction caused by the locking bolt, isn't just the area involved, the sharp point digs in and it's not about friction anymore beyond that point.. Either way it need to be re-designed with a better clamping system.
29th Jun 2013, 02:43 PM #22Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
If the tubes are a reasonably close fit you could split the sleeve, weld on a couple of lugs for a bolt and you'd have a simple split clamp that should not damage the upright. I think 25 & 30mm square tubes can fit nicely if you choose a suitable wall thickness and grind a relief for the seam. You could make the sleeve longer and add more bolts till it gripped enough. OTOH a close fit may cause jamming issues. I'm not familiar with the application.
29th Jun 2013, 02:45 PM #23Most Valued Member
29th Jun 2013, 04:27 PM #24Most Valued Member
- Healesville
- 2,129
This type of clamping system works quite well on round or square tube.
Not a very good pic but I think it should give you an idea how to go about it
29th Jun 2013, 09:11 PM #25Most Valued Member
- Jun 2012
- SA
- 1,649
One of the most intriguing locking systems I've seen (and owned) was the double knuckle system that old air cooled VW's used on their car jack.
How that system locked onto a round piece of smooth steel pipe and held the weight of the car was quite amazing.
Anyone that's ever had a vee dub beetle and seen the jack will know exactly what I mean.
Rob
30th Jun 2013, 09:18 AM #26Senior Member
- Newstead Victoria
- 459
have used the hard facing rods with oxy acet before to build up valves on old cars ex valves where you cant find replacements as the stem length is the problem. just break off the flux and weld with neutral flame better control and you can see where to place the filler rod material.0.02cents worth John.then grind to suitable angles.
30th Jun 2013, 09:24 AM #27Senior Member
- Newstead Victoria
- 459
30th Jun 2013, 09:48 AM #28
I have never owned a vee dub but I have helped a mate and recall jacking his up. The jack mounted into tubes under the running boards and when the pressure was applied you could not open the door. Don't remember anything about the jack mechanism tho and I am intrigued.
Edit I just googled them. I think I need one of these re j.ashburn's suggestion.
30th Jun 2013, 10:15 AM #29Most Valued Member
- Jun 2012
- SA
- 1,649
Yes, the shaft got in the way.
Using one as a porta power would be interesting.
Getting back to the pointy tip question, if you want to go this way maybe you would be better off putting a hard bronze tip (brazing rod) on the bolt end.
This would not gouge the metal it's screwing against, yet is very hard and durable.
Rob
30th Jun 2013, 10:30 AM #30Senior Member
- Newstead Victoria
- 459
Will see if I can dig 1 up for you here some extras around here in the mass of junk. they work well and should be in everyone's tool kit. i will be up your way next week and if you want 1 p/m me John. think is 3/4 pipe that slips over we pushed out the pillars of a side swiped datsun 1600 many yrs ago it came out perfect. Was poor and still am but do have hydraulic friends now.Porta power not the other ''hydraulic friends'' those who will lift any thing Lol. John.
putting hard point on small bolt?
By Mathuranatha in forum WELDINGReplies: 1Last Post: 28th Jun 2013, 06:18 PM
