Results 16 to 30 of 38
Thread: MECA Rotary Tables
26th Jun 2013, 04:15 PM #16Philomath in training
- 6,559
I was just about to say "What about Yuasa"?
I do like the notched edge for direct indexing. That would be handy.
My R/T has a grub screw (locked with a grub screw - actually it's grub screw then ball bearing then grub screw) that sets a maximum for the shaft rotation. The adjustment is for taking out backlash by rolling the screw further into the worm gear.
Check about the dividing plates - I had a 6" Vertex and it had 3 plates with it but the 8" Yuasa I now have only has 2 plates. If you want hole counts and dimensions let me know and I'll do a sketch.
26th Jun 2013, 07:11 PM #17Golden Member
- Jun 2004
- Kyabram. Vic
- 632
Ray,
Thanks for the offer of the dividing plates; but I already have a set for the 8", so hoping that they are a direct fit.
Ken
27th Jun 2013, 02:21 AM #18
Ray I believe I have the origional manual for mine, The auction it came from was a closing down proto type facility. The Meca was in it's origional timber box (felt lined) with all the dividing plates bar one, But I havn't needed that one yet But when I first opened the box it was full of paperwork reciepts from callibration tests and im almost positive the manual was there with it all. The table I have used it abouy 5 times in the last 2 years so I am happy to have an educated guess and say I have used it more than anyone in the company I baught it from has,
Mine is thr compleate kit...,.,.,.
So Ray if you don't mind if I photocopy them for you to haqve your own book then.
Kind Regards,
Matthew Gischus`Warning Disclaimer
27th Jun 2013, 02:30 AM #19
27th Jun 2013, 01:04 PM #20
Thanks Matthew, you are a life saver!
I've sent you a PM with my contact details.
I can vouch for the smoothness of operation, when we first got them home and were trying to figure out why one was stuck, Josh had flushed them with kerosene and filled them both with oil, both of them had dried out.
You could spin the handle and even with just a gently spin the table kept moving smoothly... silky smooth and rock solid..
The restoration is coming along, Josh is doing all the work ( as usual! ) and we might even get to a coat of primer before the weekend... pictures later.
28th Jun 2013, 12:23 PM #21Golden Member
- Oct 2012
- Australia
- 621
While the main casting is soaking away in the caustic soda bath, there is little to do on the rotary table but to clean off the rust and get the bits and bobs into a better condition. I think I may know why this table was seized up, there is a small crack on the worm drive carrier(thanks Stuart) that would allow the oil bath to drain away all be it slowly. See pic bellow
The table
Some of the bits and bobs
28th Jun 2013, 03:02 PM #22Most Valued Member
28th Jun 2013, 03:59 PM #23Golden Member
- Oct 2012
- Australia
- 621
29th Jun 2013, 10:24 PM #24Senior Member
- Nov 2012
- Blue Mtns
- 115
Well done the Meca stuff is first class.
10th Jul 2013, 05:54 PM #25
Here's one for GregQ, did you know you can get custom spray cans?.... look for a U-POL dealer, they can mix up any colour you like ( as long as they have the formula ) ...
Hey presto spray can of RAL 6011....
18th Jul 2013, 10:05 PM #26
Josh and I got one Meca rotary table finished and re-assembled, just finished the touchup paint, and cleaned off some overspray.
As well as the new handle we also had to make new table locks, made them the same as the originals.
One down one to go..
PS: The oil leak caused by the crack on the worm drive carrier was repaired by filling with brazing and re-machining the seal.. here's hoping it doesn't leak..
18th Jul 2013, 11:21 PM #27
Good work
The graduated ring looks gleaming, looks like one of you spent some time polishing! I like the way the coolant channels are made in the base, i seem to end up with it everywhere when i use my little R/T.
And here was you thinking i would finish the D/H first. I have been a little pre occupied, and now i have to play tetris with the shed to make some space. I also had some problems with the topcoat not bonding to the primer filler properly and puckering.....i've have to strip the top off almost all the parts and go again.
30th Apr 2020, 06:24 AM #28Novice
- Apr 2020
- Germany
- 12
Hi Matthew, I bought myself an used meca rotary table with indexing stuff on it and noticed about 135° of backlash on the hand wheel.
Is there some information regarding tuning the spindle backlash in your manual?
I'd be very interested in that
I know I have to turn the excenter tube to engage/disengage the spindle.
As it is a duplex worm gear, I heard I have to trim the axial position of the spindle in relation to the sprockets position with shims. Tried doing this in -> and out <-, but it doesn't really change that much.
Shimming somehow doesn't change the backlash, but makes it more loud turning into one direction while the another direction keeps "quiet"
Most noticable difference is when over-turning the excenter, without the stop bolt in it. But this of course makes it noisy and rough when turning...
Here are some pictures of it
IMG_20200429_203706.jpgIMG_20200429_203811_2.jpgIMG_20200429_203735.jpgIMG_20200429_203931.jpgIMG_20200429_203859.jpg
Stunning result!
Do you know the exact type name of yours?
30th Apr 2020, 08:32 AM #29
Hi MX39,
Welcome to the MetalWork Forums.
You have replied to a seven year old thread but some of the posters are still currently contributing to the Forums.
To explore the other areas of our forum here's a guide on how to to navigate our Forum and find all the other forums and help pages.
Goto the FORUM box in the top left hand corner of the page and click the down arrow. This will bring up a pull down menu that has Forum Home at the top
Click Forum Home which will present a scroll down page entitled Forums and members help.
Our rules, the Terms of Service are right at the top ,we encourage you read them.
Below that are all the various help pages and subforums that make up our MetalWork forum.
We look forward to your questions and contributions of knowledge to the Forum. Please visit the Welcome Wagon sub Forum where you can introduce yourself and tell us about yourself.
30th Apr 2020, 09:02 AM #30Most Valued Member
- Charlestown NSW
- 1,673
Rotary Tables
By simonl in forum METALWORK GENERALReplies: 104Last Post: 22nd Jan 2013, 10:18 AM -
Which rotary table??
By xr6t in forum METALWORK GENERALReplies: 20Last Post: 5th Mar 2010, 09:22 AM -
Rotary Table
By graemet in forum METALWORK GENERALReplies: 26Last Post: 8th Oct 2008, 09:34 AM
