Results 1 to 6 of 6
    May 2006
    Lake Macquarie NSW Australia
    73
    Default O1 carbon steel - purchase
    Where can I go in Newcastle/Hunter region NSW Australia
    and physically purchase flat bar 2 or 3mm x 40 & 50mm wide
    in small quantities i.e. 1.000m
    I do not want to order on ebay or internet.
    regards, Ned
    Aug 2010
    Soldiers Point, NSW
    60
    10
    Ned..... Not sure where in Lake Macquarie you are but Bluescope Steel at Cardiff does stock a range of steel products (including flat). If that is no good then let your fingers do the walking and type steel merchants into the Yellow Pages directory. Even small fabricating workshops will often sell small quantities of steel, I'm sure there will be one near you. I usually use Hunter Metal Mart at Heatherbrae but that would be further than you need to travel I'm sure..... regards Twosheds.
    Jun 2008
    Victoria, Australia
    74
    5,080
    Hi Ned,
    Do you specifically want O1, or do you just want high carbon steel? If it's for a blade, ( just guessing ) there are other sources of high carbon steel.
    I know you specifically said don't want to buy on-line, but $14 for 18" x 2" x 1/8" is hard to beat.. Precision Ground O1 Oil Hardening Flat Ground Stock / Tool Steel plus postage
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    Victor's is the cheapest by a long way, even after post. I can't get anything but round locally, and its pricey once you get up to any decent size.
    Ew
    Sep 2009
    Newcastle
    342
    Bohler-Uddeholm (Cardiff) carry quite a range of steel, but mostly round I think. Happy to sell in small quantities by weight.
    May 2006
    73
    Thanks guys for the leads I'll give them a try.
    regards, Ned
  1. Carbon Steel Bandsaw Blades
    By Auskart in forum METALWORK GENERAL
    Last Post: 27th Feb 2013, 07:09 AM
