Results 1 to 15 of 27
Thread: Face plate runout
22nd Jun 2013, 07:01 PM #1
Face plate runout
Hi
A general query for the " experts "
When using a face plate. What would be an acceptable runout at the outer edge of the faceplate , of say 9" diameter ?
If there is any runout at all in the centre of the faceplate, or spindle, where the faceplate is fixed to the spindle , this error would be amplified at the outer edge .
Mike
22nd Jun 2013, 07:24 PM #2Philomath in training
- 6,562
Schlesinger says for a facing lathe, face plate run out should be maximum 0.06mm per 1000mm of diameter. Nothing for more normal beasts.
22nd Jun 2013, 07:33 PM #3Most Valued Member
As a flate plate and my "trued up" on the lathe...... I'd say as close to nothing as makes no difference.
The next question is "how much runout is acceptable to you?"
Or am I not understanding the question again?
22nd Jun 2013, 07:36 PM #4Member
- Brisbane
Funny this question has come up. I was measuring my lathe runout last night and found on the outside edge of the spindle plate (ie. no chuck or faceplate installed). I measured a difference around 0.05mm between minimum and maximum readings.
I have been trying to find a good definition it ion of runout and I think I need to divide that reading by 2 to attain a runout spec making my runout being 0.025mm. Can an "expert" confirm?
Measuring the runout on the inside of the spindle taper, my DTI did not show any deviations. It is only accurate to 0.01mm so I was considering purchasing a more accurate one that could measure 0.002mm.
22nd Jun 2013, 07:39 PM #5Most Valued Member
22nd Jun 2013, 07:47 PM #6
Depends on how far out it is, if it's more than 0.1mm ( 4 thou ) I'd think about taking a skimming cut just to true it up. Less than that, it would depend on what you were making as to whether it mattered.
Oh, and don't forget there are two axes involved, radial and axial...
22nd Jun 2013, 07:49 PM #7Member
- Brisbane
22nd Jun 2013, 08:03 PM #8Most Valued Member
- 4,890
Have you used the face plate before,if so was there any run out then.
If not then you must have some problem with the spindle register.
If this is the first time you have mounted the face plate then take a truing cut from the face and OD,if the rear of the plate is also running out and this distracts you also take a skim of the rear edge of the plate.
If you wish to just know what might be acceptable runout,then I would say what ever you would accept for a 4 jaw chuck,in most cases this would be none.
22nd Jun 2013, 08:42 PM #9
Yes, I meant to write: the runout in the direction from headstock to the tailstock e.g., that's the axial runout I think.
Yes I did think of a skimming cut as a solution to this problem . But, if the faceplate register ( the face that closes onto the spindle register ) is not true, then the face plate will always be wobbly - in that case maybe it would be worthwhile face grinding the register of the face plate .
BTW I am talking about threaded spindles here .... not those modern camlock things
Mike
22nd Jun 2013, 08:47 PM #10
22nd Jun 2013, 08:58 PM #11Most Valued Member
Is it custom to face the faceplate on a lathe when you first purchase it to ensure it runs true and then stamp somewhere on both the faceplate and spindle so that you can marry up the two surfaces again for repeatability?
OK now I'm thinking this may only be relevant to camlock spindles where you have 3 different positions to mount said faceplate? What's the go with these old fashioned screw on spindles? You just screw them on and hope for the best?
Edit: Also is it fair to say that radial runout is irrelevant on a faceplate?
22nd Jun 2013, 09:11 PM #12Most Valued Member
- 4,890
If you were to grind the register what would you set up to.
If the face plate has been made for the type of lathe it is to be fitted on then the register would of been machined when the thread was cut,and should be running true/square to the spindle. to the spindle
22nd Jun 2013, 09:15 PM #13Most Valued Member
- 4,890
Screw on spindles whether on older machines or current models have a register face that locates tooling square to the spindle.
As long as the register on the spindle or register on the tool is not damaged/burred tooling that is placed on the spindle should locate to the same position all the time.
Axial runout in my opinion should try to be removed just for appearance if for no other reason,it can be very off putting when you see a wobble.
22nd Jun 2013, 10:04 PM #14Member
- Brisbane
All good advice if you have a threaded spindle but I don't. My chuck is held on by 3 bolts.
i have tried my 3 jaw chuck in all three possible positions and have not seen any significant difference in runout and I know my 4 jaw (or collet spindle adapter) can fix the misalignment however, I was really interested in the definition of runout which is pretty elusive when a noob does a bit of googling.
22nd Jun 2013, 10:04 PM #15Most Valued Member
What makes you think that?
Thats why you face the faceplate on the machine it will be used on. Now you'll want a good cross slide etc etc. But even if the cross silde is shocking and the flate plate doesnt end up "flat". it should still have zero axial runout.
Hi Rob,
TIR to me means exactly what is says. Half TIR to me may mean "runout"
When you move the 3 jaw. does the run out move with the chuck or stay with the spindle?
StuartLast edited by Stustoys; 22nd Jun 2013 at 10:10 PM. Reason: edit for this and that
Face plate fix
By Stustoys in forum METALWORK GENERALReplies: 35Last Post: 13th Nov 2010, 12:42 AM -
Face Plate Clamping
By Sterob in forum METALWORK GENERALReplies: 20Last Post: 3rd May 2007, 11:53 PM
