Results 256 to 266 of 266
Thread: Deckel FP2LB
31st Aug 2013, 01:26 AM #256Golden Member
- Oct 2012
- Australia
- 621
Bob,
Well it's behind the door so doesn't that mean it gets indoor paint?
Honestly probably not, I doubt that I will bothered with repainting behind the covers, All the paint there seems to be in good order, plus I need to be able to leave a clue for next owner in 40 years time to know what the original colour was.
In the second photo; the one with the door open, you can see where I intend to put the VFD, inside that little compartment where the wires are coming out.
On another topic: I want to replace the sight glasses for the oil reservoirs, I'm after good suggestions for how to take them out and second where to find replacements, I suppose I could make some.... hmmm i'll think about that one.
-J
31st Aug 2013, 01:40 AM #257
Are they sight glasses or sight plastics Josh?
The vernier had plastics, mostly broken or so scuffed they couldn't be seen through. I got new ones from RS. They were standard BSP threads, 1" and 3/4" i think. The old ones had a pair of holes for pin spanners, the new ones had hex heads.
Ray tried to call before, but didn't answer when i called back, you road tripping tomorrow or not?
31st Aug 2013, 02:04 AM #258Golden Member
- Oct 2012
- Australia
- 621
31st Aug 2013, 08:05 AM #259Philomath in training
- 6,540
I had that problem with the Sajo as the mounting thread was something like M16x1.25(?) - non standard anyway. I ended up making the sight glasses out of steel and then using gasket goo "gluing" some glass discs into the front. I then used a paper hole punch, scissors and some mylar to make up a star shaped piece and mounted that in a shallow groove in the back of the steel.
Pictures and a sketch if you like. One advantage of the glass was that it does not discolour with age.
1st Sep 2013, 12:25 AM #260Golden Member
- Oct 2012
- Australia
- 621
Thanks Michael,
I like the idea of proper glass. Since posting I have had a little bit of a look around online, Albert Kuhn have a nice range of stuff that is feeding me other tangential ideas, I stumbled on this idea which I don't mind telling that I plan to make one adapted to suit a Relaing M4.5 thread so that way I would only need one olier and one grease.. So simple I don't know I had not thought of it, thread the outside of a type K to fit a type D it must be a bit like the cat flap as it requires true genius to put a door in a door.
-J
1st Sep 2013, 10:13 AM #261Philomath in training
- 6,540
Apologies in advance for the quality - I'm not feeling 100% at the moment. You should be able to get the idea though.
2nd Sep 2013, 12:52 PM #262Golden Member
- Oct 2012
- Australia
- 621
2nd Sep 2013, 02:00 PM #263Philomath in training
- 6,540
Gee Josh - given the speed that the bearing cap was produced I expected to see finished product by now.
I have some Mylar film if you need some.
(Getting better thanks - one of those 24hr bugs that make you think you are going 1/4 speed)
2nd Sep 2013, 02:36 PM #264Golden Member
- Oct 2012
- Australia
- 621
2nd Sep 2013, 07:05 PM #265Philomath in training
- 6,540
3rd Sep 2013, 12:49 PM #266Golden Member
- Oct 2012
- Australia
- 621
I shrunk my Deckel FP1 ...
By MuellerNick in forum METALWORK GENERALReplies: 16Last Post: 13th Sep 2012, 01:41 PM -
Beer on tap at Friedrich Deckel??
By Anorak Bob in forum METALWORK GENERALReplies: 13Last Post: 9th Jan 2012, 05:13 PM -
Cheap Deckel mill?
By neksmerj in forum METALWORK GENERALReplies: 3Last Post: 6th Jun 2011, 11:44 PM -
Where's the Deckel mill?
By neksmerj in forum METALWORK GENERALReplies: 50Last Post: 19th May 2011, 12:32 AM -
Greg's Deckel????
By neksmerj in forum METALWORK GENERALReplies: 1Last Post: 9th Mar 2011, 09:31 PM
