Results 1 to 11 of 11
Thread: Mounting your VFD?
19th Jun 2013, 07:08 AM #1Diamond Member
- Sydney, NSW
- 1,249
Mounting your VFD?
Hi,
I recently purchased a new VFD for my Hercus Mill :
Updated NEW 1 5KW 220 250V 7A 2HP Variable Frequency Drive Inverter VFD T7 | eBay
I'm taking it work so it can get wired up but where do I mount it? I was thinking of making a shelf to put it on the side of the mill. Or maybe in the base where the coolant would of went.
Where does everyone else put there's? At this stage I doubt if I'll be running more than one machine of the VFD but who knows in the future.
Cheers Ben.
19th Jun 2013, 09:13 AM #2Member: Blue and white apron brigade
- 7,182
19th Jun 2013, 09:41 AM #3Most Valued Member
Hi Ben,
I must admit that compared to the rest of the project (VFD conversion) I didn't really put a huge amount of thought into where to put the VFD. My main concern was to make sure it didn't get wet (if ever I did end up using coolant) and I dare say that swarf getting inside them (especially in the circuit board) would probably not be too good for them either. Mine is same as Bob's, on the wall behind the machine where it will get all the ventilation it needs but nothing else.
All the best with the conversion.
19th Jun 2013, 12:41 PM #4Most Valued Member
Hi Bob,
Do you have a picture of the bottom of the VSD on your drill?
I've never liked that area of my wiring and you seem to have fixed the problem.
19th Jun 2013, 02:25 PM #5Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
not on the floor
hi mate. did you have a read of what they recommend in the manual?
not only should coolant and swarf be avoided but they dont like dust much either. maybe a cabinet with a hinged door so you can access the controls if needed. and keep in nice a protected when not needed..
if you take the time to set it up. you may not really need to touch the operator panel on front of the vfd.
when i want to turn mine on i use the lathe power switch to turn on the vfd. When i want to turn the spindle i use the lathe contols to make it run. So it really can just stay in its ventilated box.
aaron
19th Jun 2013, 04:10 PM #6Member: Blue and white apron brigade
- 7,182
19th Jun 2013, 04:45 PM #7Most Valued Member
Thanks Bob,
Its better than my effort. While mine is all double insulated, the strain relief is well........ ummmm, lets just call it "less than good".
Hi Ben,
All my VSDs are out in the open(well one is in an enclosure but it has no front and a perforated top and bottom). I'm yet to have a problem but that doesnt mean its a good idea. I see it as a toss up. You either leave it out, its small and cooling wont be a problem but swarf/dush maybe or put it in an enclosure which makes it much larger, swarf/dust wont be an problem but cooling maybe.
19th Jun 2013, 07:17 PM #8Senior Member
- Aug 2009
- Quindanning, WA
- 175
I put mine in an electrical enclosure with a couple of fans for ventilation... Overkill but my shed is quite dusty and sees a bit of condensation. Also allowed me to put a couple of breakers in for the lathe control power supply.
19th Jun 2013, 07:24 PM #9Diamond Member
- Sydney, NSW
- 1,249
Hi,
Thanks for all the replies. Good food for thought. Due to my job I move around a lot, so I'm thinking I'll make up a shelf on the side of the mill with the VFD enclosed somehow. Plenty of time to think about it, not sure when my mate will wire it up.
Cheers Ben.
19th Jun 2013, 08:59 PM #10Cba
- Aug 2007
- 68
- 1,410
X3 mill (direction and speed control on the front of the mill head, right under the top cover....). The Yellow/red mushroom switch on the very right under the workshop fuse box, this cuts all power to the workshop except the ceiling lights. The entry door is actually just to the right of this switch.
X3 mill VFD close-up
X3 mill VFD inside. I uses an Altivar28 with homemade external brake resistor.
Emco lathe VFD. Notice the start/direction switch above the headstock, and the big black speed pot wheel on the column between headstock and the DRO above it... and if look again at the first picture, at the very left, on the taable leg right under the tabletop, you see the big red mushroom emergency stop....
Emco lathe VFD box inside. It uses a Siemens micromaster VFD, with homemade brake resistor. The big power supply on the left is for an electric automatic feed.
Hercus VFD, more details can be seen in a recent thread. It uses an Omron VFD with detacheable control panel, now mounted in the box above the headstock, where also the on/direction selector and the speed pot reside...
My Waldown drill press with VFD
The Lenze VFD is inside a recycled instrument cabinet.....
whilst I put the speed pot and direction control in a cast box on the left, it also holds an old reading light (the red thing)....
When I come around to it, I want to add a twin foot pedal control, to have both hands free to hold the vise and the quill star wheel.... a project that has been put off for years....
Hope you find some inspiration, Chris
19th Jun 2013, 09:21 PM #11Most Valued Member
Mounting a DRO
By wafarmer in forum METALWORK GENERALReplies: 7Last Post: 1st Jun 2007, 09:18 PM
