Results 1 to 15 of 16
Thread: Chuck removal device
31st May 2013, 10:17 PM #1
Hi
I spotted this on the cover of a MEW mag.
Seems like a neat way of removing sticky chucks from threaded spindles . A leather strap tool, similar in design to the auto oil filter tool
What do you think ?
Mike
31st May 2013, 11:04 PM #2Most Valued Member
Been a long time since I had anything to do with threaded spindles, but its the the "other end" people normally have problems holding and thats when they damage things?(like back gears)
31st May 2013, 11:20 PM #3
Looks like Fidos collar received a makeover.
Whatever gets the job done.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
1st Jun 2013, 01:36 AM #4Most Valued Member
Best chuck removal tool I've seen (for a 3 jaw anyway) is a short length of 2" hex with a steel tommy bar welded onto it. For a 4 jaw I guess you could use 2" square bar. Maybe even mill a square on one end of a 6" length of hex to make a double-ended tool. Handle could be screwed into the tool. Picture a mallet with a hex head on one side and a square head on the other. Although it's probably just as easy to insert a bar between the jaws of a 4 jaw.
1st Jun 2013, 02:41 AM #5
1st Jun 2013, 02:43 AM #6
1st Jun 2013, 06:29 AM #7Most Valued Member
- Oct 2007
- 3,112
I have that exact strap wrench, and coincidentally I was using it just the other day. Normally I just remove my chucks by putting the key in and giving it a tap with the back of my hand.
1st Jun 2013, 06:49 AM #8Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
1st Jun 2013, 10:36 AM #9
The "Back" of your hand? The first time after I got my lathe It took some getting off but since then It has only required a bit of a tap but to do this with the back of the hand I don't understand. That's the bit that always hurts like %&&% when I knock it on something. Maybe I am just not tough enough.
1st Jun 2013, 02:09 PM #10Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Why not chock the chuck to the bed and switch the motor on in reverse for a split second?
Worked for me, after a few attempts, and taking precautions to prevent the chuck coming off completely (tailstock, although not needed).
Jordan
1st Jun 2013, 09:55 PM #11Most Valued Member
- Oct 2007
- 3,112
Maybe Sadly the post was the product of 36 hours between decent sleeps, the palm of my hand was what I meant. The point being that some people see a thread and seem to think they have to tighten whatever goes on it to within half a pico-Newton of its ultimate yield strength. In fact if the lathe is being used in normal rotation and with even semi-intelligent use, there's nothing to be gained from doing other than just snugging the chuck up and it will unscrew again very easily.
Pete
1st Jun 2013, 10:39 PM #12Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Jet Lag
I dont know how you cope with this flight thing.
We just returned from England after a 22 hr flight & suffering from jet lag.
Totally punched out !
Any clues on how to rectify or reduce the time to return to normal ?
regards
Bruce
ps Have used the granite surface plate purchased from you a while back.
It been a very handy piece of equipment.
2nd Jun 2013, 12:37 AM #13Most Valued Member
- Oct 2007
- 3,112
I'd often joke to people when they'd say that. Ok how would you now feel if I said you had to turn around and go back the other way 24 hours after you arrived? Have a few days off, then do it all again. Not such a glamourous profession at times!
In all seriousness though Bruce, get outside in the sunshine if possible, and spend as much time in it as you can for a couple of days. The more sunshine you can get, the faster you'll "reset".
Failing that? Copious amounts of alcohol!!!*
Pete
*Shame I don't typically drink
2nd Jun 2013, 01:29 AM #14
Makes more sense. I agree totally with the tightening. What's this? "semi-intelligent use,". Got me stumped! That's a big word there but don't get me started cos you wont be able to stop me.
There are so many things that people act in an unitelligent way about. One example is gas cylinders, specifically fork lift fuel cylinders. Only a turn or so of the valve is needed but how many times do people turn the valve on fully and then hard against the stop just in case there is not enough gas coming out. Then when you come along you don't know whether the valve is open or closed.
Oops! I told you not to get me started.
2nd Jun 2013, 09:11 AM #15Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Holding the chuck is not usually the problem; it's holding the spindle.
chuck removal ..spindle old
By morrisman in forum METALWORK GENERALReplies: 22Last Post: 23rd Jan 2012, 05:23 PM -
Pistol drill - chuck removal etc
By Bryan in forum METALWORK GENERALReplies: 10Last Post: 12th Dec 2011, 10:45 AM -
Chuck removal
By Godzilla98 in forum THE HERCUS AREAReplies: 11Last Post: 30th May 2009, 06:19 PM
