Results 1 to 12 of 12
Thread: Mitutoyo threads-again.
25th May 2013, 11:11 PM #1
Hi All,
I know Stuart chased himself silly trying to match a mit thread some time back. I have looked but cant seem to find the thread.
Anyway, last week i bought 2 mit indicating mics, a 1-2" and a 25-50mm. They are in very good condition, work smoothly and the anvil faces are still like mirrors. There is just one problem.....the countersunk screws out of the cover plates are missing on both of them!
I checked one of the mechanism mounting screws and it seems to be the same thread. The screws measure 1.85mm across (.073"ish) and the pitch to my eyes is 60tpi.
I've checked all the standard threads i can think of but none match. Any thoughts?1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
25th May 2013, 11:33 PM #2Most Valued Member
Hi Ewan,
My thread wont help as it was M4.
I wonder what the story behind the missing screws is?
I assume you are looking at a very short length of thread. Couldnt be 63.4tpi could it? M2 0.4?
25th May 2013, 11:51 PM #3Member
- Apr 2013
- Karana Downs QLD
- 78
Might be BA?
Hi there Ewan & Stuart,
Being an old Instrument Fitter (AKA 'Clockwinders'), I would have assumed the missing screws would be BA.
BS 93 British Association (B.A.) Screw Threads Data Charts
I have a few BA taps & dies, so tomorrow (SUN) I will have a look to see if one is close to the size you have described.
It's great to be back in the shed!! Regards, Daryl
26th May 2013, 12:12 AM #4Novice
- Dec 2010
- japan
- 15
from japan
if you couldn't find them let me know the exact size.i will send it to you from japan.there is a shop in osaka which is specialize of all kind of nut bolt screw.
26th May 2013, 10:10 AM #5
BA would be my guess as well. Looks like #9 BA from DarBee's chart.
26th May 2013, 10:46 AM #6Senior Member
- 122
Ring MTI Qualos. They are service agents for Mitutoyo equipment.
More than likely a standard Mitutoyo screw they will have in stock.
M.T.I. Qualos
26th May 2013, 03:10 PM #7Most Valued Member
- Oct 2007
- 3,112
I've checked a number of Mitutoyo products here and they seem to normally use M2 for case screws like that. Same as the back plates in dial indicators if that's of any use. They are made in Japan and I'd be very surprised to see anything other than metric being used.
Pete
26th May 2013, 04:53 PM #8
Hi there Ewan,
If you can wait a day or two, because I have a big drive tomorrow to collect my surface grinder and the diesel engine I won on grays. I probably have what you are chasing in large quantity. I will send you an assortment on Tuesday of all the BA and miniature metric and imperial thread screws as a have thousands. I picked up bpxes and boxes of them at an auction once. And I really don't think i'll miss a few.
So just pm me your addy.
MattWarning Disclaimer
27th May 2013, 12:10 AM #9
Thanks Guys.
I had wondered about M2 but though .15 undersize on diameter was a bit much.
Thats a great offer Matt, PM sent.
Cheers1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
27th May 2013, 09:19 AM #10Most Valued Member
- Oct 2007
- 3,112
27th May 2013, 10:42 AM #111915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
27th May 2013, 10:43 AM #12Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
Its hard to imagine that Mitutoyo would be using anything other than metric threads in their instruments, but a #1 UNC screw does have a 1.8542 OD and 64 TPI.
https://en.wikipedia.org/wiki/Unified_Thread_Standard
You can buy small packets of tiny metric screws from Jaycar and similar electronics stores if you want to try an M2 in the hole.
Mitutoyo DTI
By jack620 in forum METALWORK GENERALReplies: 11Last Post: 26th Apr 2013, 04:32 PM -
Mitutoyo Threads
By Stustoys in forum METALWORK GENERALReplies: 84Last Post: 20th Jul 2012, 11:22 PM -
Mitutoyo Micrometer
By drsed in forum METALWORK GENERALReplies: 11Last Post: 26th Mar 2012, 09:42 PM
