Results 331 to 343 of 343
Thread: Power Hacksaws V's Bandsaws
22nd Jun 2013, 09:14 AM #331Most Valued Member
Hey Dean,
There is another thread that someone posted a link to a person who made a RT. Ive copied the link and posted here. If I was going to make a RT, I would probably find this very helpful. The guy did a tremendous job.
Building a 120mm rotary table - Home Model Engine Machinist
22nd Jun 2013, 11:14 AM #332
It's a good thread to read, I skimmed through all 15 odd pages last night. The only thing I would have done is supported the far end of the worm, although with such a small table it probably wouldn't be such a problem.
I am working towards casting again, I have done ally and brass before but would like to do iron. Rt base here I come....(albeit very slowly) I have a burner now I need some refractory and a bagful of time......
22nd Jun 2013, 05:47 PM #333Most Valued Member
Hi Ueee,
which thread is your burner in again? Are there pics of it? Is is a forced air or naturally aspirated?
I want to make a burner soon too. Would love to make a used oil/diesel burner but an LPG sounds like the most sensible approach for a beginner like myself. Are you casting with petrobond type stuff of greensand?
22nd Jun 2013, 06:57 PM #334
Here Simon, just below all those noisy crickets.......
http://www.woodworkforums.com/f267/s...burner-172344/1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
22nd Jun 2013, 09:40 PM #335
Thanks for that link Simon. It just happens that I was searching my history for "rotary table" last night and guess what came up. Yes it is a very helpful build. Arnold does a good job. I am currently reviewing all the pages I have found in the past.
Spent today fitting the canopy for the new ute ready for a trip to the big smoke in the morning where I am going to pick up some truck brake drums and slack adjusters courtesy of rascal, among other things. So I have not had a chance to even think about shed stuff.
22nd Jun 2013, 09:52 PM #336
That will be good to see Ewan. What size RT are you thinking. Will be a sizeable pour. I am going to stick with ali and brass for a while, if I get some more done that is lol. I am going to go with waste oil as I have lots of it saved up. It is cheaper to burn it than dump it.
Regarding support for the far end of the worm, one thing I am wondering is whether the commercial ones have support for the main shaft at the bottom. I would like to provide this.
22nd Jun 2013, 10:02 PM #337
Simon pulled his apart, i guess he should have some pics....
Don't hold your breath Dean. Give me a year or 2. thinking about 12" ATM1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
22nd Jun 2013, 10:52 PM #338Most Valued Member
22nd Jun 2013, 11:17 PM #339Most Valued Member
It's not on the 8" either, for reasons outlined by Stuart. Not sure it's really that necessary, the worm is not that long and they are hardened so would not think there would be much flex or movement. If you are only using it for indexing them you are not loading it up. The Vertex 8" states (assume its the same with all of them) that machining should only be done with the hand wheel rotated in CW direction although I thought this was more because there is only one "thrust bush" on one side of the worm. I replaced mine with 2 thrust bearings. HEY! Stuart, yours already came with thrust bearings as standard!
25th Jun 2013, 10:31 PM #340
25th Jun 2013, 10:34 PM #341
8th Jun 2019, 03:53 PM #342Golden Member
- Jul 2011
- 837
Originally Posted by Michael G
somewhat belatedly I looked at this thread. I got here from a recent post. I am somewhat interested in the camlock adaptor for your indexing head. Any chance of a photo when you get the chance?
Eric
9th Jun 2019, 09:18 PM #343Philomath in training
- 6,540
There is a little bit about it here
//metalworkforums.com/f65/t194573-learn-try
Are power hacksaws obsolete ?
By morrisman in forum METALWORK GENERALReplies: 21Last Post: 2nd Sep 2011, 10:03 AM -
Bertlett Power Hacksaws
By Anorak Bob in forum METALWORK GENERALReplies: 0Last Post: 11th May 2011, 04:56 PM
