Results 16 to 22 of 22
Thread: A clutch for the Douglas Shaper
26th Mar 2013, 10:24 PM #16Most Valued Member
Would have gone much better if you'd said "oh I havent tried that" lol
I'd not seen a large shaper without a brake. But as I've only seen about 5 I guess that doesnt mean much and number 6 breaks the that rule.
26th Mar 2013, 10:38 PM #17
I might be able to fit one.....although there is not much room left in there for the plates. Remember the clutch and gearbox is not original, it was a overhead drive machine...mmmmm a shaper with a flat belt......Phil knows what i mean....
26th Mar 2013, 10:57 PM #18Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Cork has some good properties for use as a clutch lining - high coefficient of friction, inherently shock-aborbing, can be used dry or wet (slight loss of CoE when oiled).
The drawback is that cork burns if overloaded, or if the clutch is slipped excessively.
My 1960 Panther M100 motorcycle has a cork lined multi-plate clutch. This bike has lugged a very heavy sidecar.
Jordan
26th Mar 2013, 11:39 PM #19Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
I once had a BSA Bantam that had a cork lined clutch. The guy told me the cork was glued with Araldite, clamped and baked in the oven. Reckoned whatever temp it was cured at would be the temp it would withstand. Within limits presumably. The bike had numerous issues but the clutch wasn't one of them.
27th Mar 2013, 06:24 AM #20Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Thanks Rob.
I agree with the videos, I took it with my phone and plugged it into the computer then uploaded it. I think I can do it straight off the phone but haven't investigated how yet. I also have a video camera that has a Youtube button, must try that one too. I must also try commentary like on Ueees' videos but having done some educational videos for work, I might not Hopefully they are well hidden enough so noone will find them
Hi Ewan,
the brake has turned out to be an added bonus. As you can see it stops pretty quick, very handy after trying to stop in the right place with the switch.
How would I go about 'putting a load' on the light outlet (and keep it clean ). I have the plug but there are no wires in it.
Phil
27th Mar 2013, 10:22 AM #21Most Valued Member
The jog button would still work, but I'm not sure how long the motor would put up with it.
I guess you have a motor lined up already? If not and you really want a jog I'd be thinking pretty hard about a VSD on the motor you have(assuming you have the 3phase motor).
Clutch and brake is far better IMHO.
27th Mar 2013, 02:22 PM #22Mechanical Butcher
- Oct 2004
- 1,898
Thanks Stuart,
Not having any experience of a jog switch, I'll be interested to see how it works.
I suppose it could be just an ordinary push on / release off action.
Jordan
Douglas Shaper
By lamestllama in forum METALWORK GENERALReplies: 41Last Post: 1st Mar 2012, 01:13 AM -
Douglas Shaper Modifications
By Anorak Bob in forum METALWORK GENERALReplies: 39Last Post: 13th Apr 2011, 02:53 PM
