Results 1 to 15 of 37
17th Mar 2013, 12:59 AM #1Golden Member
- Oct 2012
- Australia
- 621
Tuning/Restoring of a Shaper Vice
Ray picked up a vice for the shaper some time ago and I have been planing to tune it up ever since but lacking any particular need to get into better condition has been lacking nothing has been done. Soon I hope to have six massive casting for the Master Squares that will need 5-6 kg of material knocked off it so now is the time.
The make and model of the vice is lost in time, it seems to be of a good construction and breaks down into manageable parts that I can grind.
The first step will be to take off all the built up muck and other detritus and measure it up to see what it is actually like.
Here are some pics
for scale that bench is 1200mmx600mm
17th Mar 2013, 02:23 AM #2Golden Member
- Oct 2012
- Australia
- 621
Every thing is cleaned up now, a quick survey of the critical parts
Base error in flatness ~ 0.22mm
Base pivot bearing parallel to base error ~0.09mm
Base pivot error in flatness ~0.02mm
Vice main body flatness error ~0.07mm
Vice main body parallel error ~0.03mm
Vice main body to parallel to pivot ~0.6mm but it rocks so hard to measure properly
Vice main body pivot error in flatness ~tbd
Fixed Jaw Squareness of to Vice main body ~tbd
Moving Jaw parallel of to fixed jaw ~tbd
Moving Jaw parallel of guides ~tbd
-J
17th Mar 2013, 10:06 AM #3Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Josh, pretty sure that's an Elliot, very similar to mine. Will be watching intently as I want to do mine up as well.
Will you scrape your table flat too? Not much point truing up the vice if you then bolt it to a wonky table.
17th Mar 2013, 02:50 PM #4Golden Member
- Oct 2012
- Australia
- 621
Thanks Brian,
I have not had a good survey of the table, it looks to be in pretty good nick, but if it needs some carbide put to iron it will be done.
I put the swivel base on and ground the base parallel to the pivot bearing (two birds one setup) So the base is complete other than the pivot bearing flatness. I will have to scrape the inner bearing ring as it is the one that has less wear, I think I will grind the main body pivot bearing and use that to spot the bases pivot bearing.
17th Mar 2013, 05:22 PM #5Dave J Guest
I will post down my 16 inch shaper vise when your finished
It needs a couple of good strong guys to pick up the main casting when it's disassembled so you will need Ray around, LOL
Jokes aside, watching with interest.
With my swivel base you need to take the vise off the table to rotate it as the bolts and locking ring are underneath, not sure why they designed it like that.
Dave
17th Mar 2013, 05:26 PM #6Dave J Guest
Forgot to add, be careful making lots of things shinny in the shop. In a non temperature controlled room you have to watch everything for rust, and the more you have the more work it is to keep them all in good nick.
Dave
17th Mar 2013, 06:26 PM #7Golden Member
- Oct 2012
- Australia
- 621
Thanks for the shiny tip Dave; I think it's maybe a little too late :P
Vice Jaws give an lick so that I have a surface I can gauge off for Fixed jaw squareness to the main body.
Dill damage on the main body
Move Jaw guide clamps give a new lease on life
The Wear plates are no good they are now too thin and thats before I true up the clamp surface or underneath the wear plates. replacements wear plate will need to be made approx ~0.2mm thicker.
17th Mar 2013, 06:30 PM #8Golden Member
- Oct 2012
- Australia
- 621
I should add that in dismantling the vice, half a dozen shims fell out from various spots.
17th Mar 2013, 06:30 PM #9
Good work Josh.
What would be the standard clearance on the slide for a vice of this type? My shaper vice is the same style only bigger.......1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
17th Mar 2013, 06:41 PM #10Golden Member
- Oct 2012
- Australia
- 621
17th Mar 2013, 06:57 PM #111915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
17th Mar 2013, 08:23 PM #12Golden Member
- Oct 2012
- Australia
- 621
17th Mar 2013, 08:43 PM #13Most Valued Member
Hi Josh,
I have a couple that need some work also
Wear plates have me confused(unless they didnt make the pictures?).
On the nitpickey side of things, shouldn't you have scraped the top of the base before grinding the bottom?
17th Mar 2013, 09:15 PM #14Golden Member
- Oct 2012
- Australia
- 621
The wear plates are in the last picture of post #7 and missing on in the second last picture of the same post. atm they are far enough out that the moving jaw will rock/lift with the bolts fully tightened.
I suppose there are two schools of thought on that one. In this case the pivot bearing on the base was flatter than than the bottom of the base, so I decided that if I mount the base on fresh ground magnetic parallels arranged around the outer ring on the pivot then when I grind it will mean that I have less to scrape. It works out pretty well, the pivot bearing ended up better than 0.01mm on the outside ring parallel to the base. the inner ring has a bit more of a slope but it is ok at 0.02mm from parallel to the base.
I'm currently doing the same on the main body. I have the vice on the small mag chuck with the ways face down on that grinding the base of the main body so that I can use that as the spotting master for the base pivot. It also means that I will only have to take of the minimum of the top of the ways.
-Josh
I'll edit with some pics..
17th Mar 2013, 09:35 PM #15Most Valued Member
Going blind, I'd been looking at those holes thinking "well thats where I think the wear plates should go" but I didnt see them in the next picture.
I didnt mean scrap the top of the base parallel to the bottom, just flat from the bottom of the main body. So you wouldnt be taking off any more and shound t need to revisit the bottom of the base.
But I guess with your way you can tweak the top as you scrap it flat....... see what you are on about now
Shaper vice ID
By morrisman in forum METALWORK GENERALReplies: 5Last Post: 24th Dec 2012, 09:49 PM -
Shaper vice and milling vice
By morrisman in forum METALWORK GENERALReplies: 6Last Post: 5th Sep 2012, 12:06 AM -
Shaper vice project
By welder in forum METALWORK GENERALReplies: 49Last Post: 19th Jun 2012, 08:42 PM -
SOLD: Douglas Shaper Vice
By 4-6-4 in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 30th Apr 2012, 12:11 AM -
Which Shaper does this vice belong too?
By lamestllama in forum METALWORK GENERALReplies: 16Last Post: 12th Apr 2012, 01:52 AM
