Results 1 to 4 of 4
11th Feb 2013, 10:26 PM #1
Measuring microns and their decimal fractions
Some of you may have read RayG's descriptions of one of his amazing acquisitions - a late 50s to 70s HP Laser Autocollimator and auto compensated interferometer.
I've now seen it in use in person and had both my cast iron and granite surface plates 're-certified' - well, at least checked for deviation from flat.
This is an amazing process - not that easy to get your head around and quite time consuming.
My surface plates appear to both be within about 5 microns per foot. Maybe one day I'll blue and spot them against each other - if I get bored....
Here are a couple of pictures of some of the set-ups and equipment:Cheers, Joe
11th Feb 2013, 10:37 PM #2Golden Member
- Oct 2012
- Australia
- 621
Dr. Egon Spengler: There's something very important I forgot to tell you.
Dr. Peter Venkman: What?
Dr. Egon Spengler: Don't cross the streams.
Dr. Peter Venkman: Why?
Dr. Egon Spengler: It would be bad.
Dr. Peter Venkman: I'm fuzzy on the whole good/bad thing. What do you mean, "bad"?
Dr. Egon Spengler: Try to imagine all life as you know it stopping instantaneously and every molecule in your body exploding at the speed of light.
Dr Ray Stantz: Total protonic reversal.
Dr. Peter Venkman: Right. That's bad. Okay. All right. Important safety tip. Thanks, Egon.
12th Feb 2013, 03:16 PM #3
Hi Joe,
When I get some time to get the plotter going and figure out how to run the surface plate calibration software, we can have another go at that and try to produce a proper calibration chart.
Thinking back on what we did, that cast iron plate that Marco ground is probably every bit as good as the granite, especially the center section which is probably better than 2 microns... I wouldn't scrape the cast iron to match the granite, might be the other way around..
PS.. Yep don't cross the beams..
13th Feb 2013, 01:40 PM #4Golden Member
- Oct 2012
- Australia
- 621
The sensitivity really is amazing.
A while ago I used it to measure the twist in some plane bodies see this thread here. or if you prefer video here
With the setup pictured I could place a single M4 nut on one end of the bar and read off how much twist that caused in plane body to two signification figures. The other interesting effect that you could actually see happening is what happened during the application of the load and after removal. In the X10 mode (not in video) it would twist quickly after carefully putting the load on and then twist some more over the space of 30 seconds then slow down and settle. When the load was taken off the the body would spring back to 99.9% of original shape and position and then take about a minute to settle back to 99.9999999%.
measuring fanatic !
By morrisman in forum METALWORK GENERALReplies: 10Last Post: 22nd Dec 2012, 08:24 PM
