Results 31 to 35 of 35
9th Feb 2013, 06:00 PM #31Most Valued Member
Hi Phil,
I have a wobbler. That wasn't the problem. The problem was that once I had the crankcase centred in one axis I would throw it out of centre when I tried to centre the other axis. I have now successfully bored one of the crankcases using the 4 jaw and my ali jig. Used the wobbler to centre it. Pics to follow.
9th Feb 2013, 06:13 PM #32Most Valued Member
Thanks for all the help folks. Here are some pics of what I've done so far.
10th Feb 2013, 06:49 AM #33Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Outstanding Chris.
I have a big admiration for people who can machine to those tolerances. I have nearly assembled all the castings for a Stuart Turner 5A steam engine...I thought that was small!!
Well done again. As they say"where there's a will...there's relatives"
Phil
10th Feb 2013, 11:09 AM #34Most Valued Member
Thanks Phil. It's been a very steep learning curve. What has surprised (or dismayed) me is how a tiny tweak of the crossfeed dial can make a tight fit into a loose one. I should set the compound at 5.75 degrees and use the 1:10 method, but I always seem to forget.
The real close tolerance work comes next when I have to lap the cylinder and piston with diamond paste. That stage is more art than science. Because this is a 'diesel' engine it requires a very close fit between piston and bore or it won't fire. I really should have started with a glow plug engine which are less critical for fit. Too late now.
Regarding wills- I think my parents have joined a SKI Club (Spend Kids' Inheritance).
10th Feb 2013, 11:22 AM #35
Nice work Chris.
There is an Audi s6 that gets around locally with the number plate KISS. But its not keep it simple stupid, it says above the letters "kids inheritance spending spree"1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
Angle Plate - H and F M245.
By Anorak Bob in forum METALWORK GENERALReplies: 3Last Post: 5th Jan 2012, 12:24 AM -
angle plate???
By turbo TA in forum METALWORK GENERALReplies: 5Last Post: 25th Apr 2010, 09:17 PM -
Clamping piece of angle onto plate strip
By Tiger in forum WELDINGReplies: 6Last Post: 21st Jul 2009, 08:47 PM
