Results 46 to 60 of 66
Thread: Schaublin 102 lathe restoration
11th Jul 2013, 11:53 PM #46Senior Member
- Jan 2010
- 119
Good on you Rob; it's been great to follow this build along with your utube. Great looking machine; good strong stand. Happy machining.
Thanks for pics too.
cheers
Mark
12th Jul 2013, 10:09 AM #47Most Valued Member
- Jun 2012
- SA
- 1,649
Yes, everything has gone to plan, but you can't rush these jobs.
I found a bit of tin jammed under the edge of the pulley centre and held on with masking tape (yep you have to see how it was when I bought it) and wondered what that was there for.
Turns out it was supposed to correct the pulley weave - LOL.
It looks like I will have to use a test bar on this lathe when setting it up for a job. I have one I made years ago, but I may have to see if I can improve it a bit more.
I may have to use an idler roller for "V" belt adjustment.
Still a way to go.
But at least it does run now
Rob
7th Aug 2013, 06:52 PM #48Most Valued Member
- Jun 2012
- SA
- 1,649
The Schaublin is fully operational
Well, after months of work the little Schaublin is finally operational.
Late in the day when I took these photo's so had to use the flash. Will do a video of it in action soon.
Anyway here's a few photos to give you an idea of how it turned out.
I ran the test gauge along a test bar on it and my scraping seems to have been pretty successful.
Rob
7th Aug 2013, 07:09 PM #49Senior Member
- Castlemaine
- 244
Nice Work
Nice work Rob,
great watching the build on youtube.
Now you can cash in and sell in on grays.....
Piers
7th Aug 2013, 07:17 PM #50Most Valued Member
- Jun 2012
- SA
- 1,649
I just realised it's taken me 6 months to get to this point in time. Long job.
It was a heap of junk when I got it. I didn't really need another lathe, and I have often though I must have been mad to buy this, but it makes life interesting.
Now I can start playing with it
Rob
7th Aug 2013, 08:00 PM #51Senior Member
- Jan 2011
- shep Victoria
- 97
- 157
Very nice restoration Rob, well worth the effort you put in.
Eddie
7th Aug 2013, 08:12 PM #52
Nicely done Rob
I still have to go back and watch the rest of the vids. I'm getting through them....
7th Aug 2013, 08:19 PM #53
Hi Rob,
It's great to see such a nice bit of swiss precision machinery brought back to life. Documenting the project on video, is definitely a big plus.. I think it's just got at least another 50 years of life.
7th Aug 2013, 08:26 PM #54Most Valued Member
- Jun 2012
- SA
- 1,649
Thanks all.
I will do a run around with the video soon and you can get a better look at it.
I thought my motor mount was pretty crafty - it flexes a high tensile steel base plate with a large adjusting nut under the motor base.
The motor must weigh about 20 kg - it's an oldie from a shearing shed. Built like a tank. The internal wiring was OK. I had to re-do the capacitor start side of things.
Rob
7th Aug 2013, 08:40 PM #55Golden Member
- Oct 2012
- Australia
- 621
7th Aug 2013, 09:06 PM #56Golden Member
- victoria
- 499
8th Aug 2013, 01:36 PM #57Most Valued Member
- Jun 2012
- SA
- 1,649
Here's a video look at it.
My old metal lathe - early Schaublin 102 - YouTube
Rob
9th Aug 2013, 11:09 AM #58Most Valued Member
- Jun 2012
- SA
- 1,649
I've identified the weird problem with the cross slide action.
Looks like someone has replaced the left hand threaded Acme shaft and block at some stage, and as taps and dies in that configuration are pretty scarce, has just put in a right hand threaded system. LOL.
Only an Aussie would do that.
So another job, to correct - doable but will be a chore making a tap etc.
Rob
9th Aug 2013, 01:48 PM #59Philomath in training
- 6,542
What size Rob?
I bought a new nut for my compound because I originally bought the wrong size and when buying the right size I had to add to the order to get the minimum order value up, so I may have an acme nut (in 8tpi) that will suit.
9th Aug 2013, 02:11 PM #60Most Valued Member
- Jun 2012
- SA
- 1,649
Hi Michael,
Thanks for the offer, unfortunately being a Schaublin nothing is as simple as a nut
They use a tube type thread block in the cross slide (about 1" long from memory) which is pinned into place.
I'm going to leave it for a while until after I get a few other more pressing jobs out of the way. I'm a bit Schaublined out at the moment - been such a long haul. It's a PITA for sure.
I may still take you up on a bit of that foam cutting wire if the offer still stands though.
Rob
Portass Lathe Restoration Project
By bwal74 in forum METALWORK GENERALReplies: 44Last Post: 22nd Jul 2012, 08:27 AM -
MARS Atlas Lathe restoration
By onthebeachalone in forum METALWORK GENERALReplies: 39Last Post: 18th Jul 2012, 11:53 PM -
Schaublin lathe
By Bryan in forum METALWORK GENERALReplies: 24Last Post: 14th Dec 2010, 09:26 AM -
Lathe Restoration
By schwartzy in forum METALWORK GENERALReplies: 14Last Post: 11th Feb 2008, 12:46 PM
