Results 1 to 11 of 11
Thread: Dry milling aluminium dangers?
27th Jan 2013, 10:45 AM #1Golden Member
- Aug 2012
- Australia
- 645
Does dry milling aluminium create any dangerous dust?
27th Jan 2013, 11:11 AM #2Most Valued Member
- 4,887
I wouldn't think so,but it would probably create poor surface finish,excessive build up of swarf on cutting tool edges (clogging) and heat.
27th Jan 2013, 02:04 PM #3Member: Blue and white apron brigade
- 7,183
Although pure Al has been "linked to some health problems" I doubt any of you are working with pure Al but rather with its alloys.
In alloys, the Al is generally considered less of a problem than the additives, eg Si, Mn, Cu, Zn, Cr, Pb and Ni, with the latter two are not deliberately added but may be present due to processing.
I do recommend reading the full MSDS on all the alloys, the 6XXX type alloy MSDS is available here (http://www.alcoa.com/global/en/envir...oadMSDS=180947)
Interestingly the recommended OHS level for Al in air is the same as for soft woods (TWA 5 mg/m^3)
Bear in mind that what your eyes see is rarely the full story. Machining and sanding creates a lot of "invisible" dust that hangs around in a workshop for hours and so you may think you are OK when you are not.
Risk will depend on total exposure (concentration in air X time) but at a minimum I would be wearing a P2 level dust mask.
If you live in Perth, I could be available to come and measure your dust levels for you
27th Jan 2013, 02:26 PM #4Most Valued Member
27th Jan 2013, 03:08 PM #5Member: Blue and white apron brigade
- 7,183
It probably helps quite a bit - maybe even enough to negate the problem. Next time I have a piece on the lathe I will will do a with and without test with my particle detector.
I don't think low speed turning and machine generates a lot of dust anyway compared to a say a CNC machine or sanding.
I hope you arent talking about alzheimer's, last I heard that guy is looking for a new career
You also have half of thermite
27th Jan 2013, 04:15 PM #6Most Valued Member
28th Jan 2013, 01:12 PM #7Golden Member
- Apr 2009
- Kingswood
- 930
There was a thread posted recently in the UK describing a chap suffering a severe face flash while grinding steel on a bench grinder, major burns and a time in hospital.
Apparently his son had ground some aluminium previously and didn't clean up the debris.
John.
29th Jan 2013, 01:47 PM #8Most Valued Member
- Jun 2012
- SA
- 1,649
Grinding aluminium is not recommended.
It clogs up the grind stone to the point of uselessness and can cause the stone to disintegrate from surface pressure build up of the metal, especially as it gets hot and expands from the friction.
Are you sure that wasn't the issue ?
Rob
29th Jan 2013, 11:15 PM #9Golden Member
- Apr 2009
- Kingswood
- 930
Rob,
I agree with your comments, but the posting is proving difficult to track down.
When I find it I will post the link, perhaps someone else can assist here.
My memory says that there was virtually no follow-up details.
The age of the son was not stated, so it could have been a junior experimenting on dad's tools.
John.
1st Feb 2013, 09:42 AM #10Golden Member
- Apr 2009
- Kingswood
- 930
Located the reference, not a forum post but a magazine item.
Letter to the Editor, from J. Purdy in BC Canada, Model Engineers Workshop May 2001, No. 73, Page 57.
Described as a "2 foot diameter fireball of no more than 1/2 second".
Damage was similar to severe sunburn, first degree burns to areas of the face and hands, with some skin actually hanging off.
Clothing smouldering.
No eye damage due to use of glasses.
The aluminium content was described as 12 x 1/8 inch pop rivet heads ground off.
Makes you think, doesn't it.
How close have many of us been to the same scenario ?
John.
2nd Feb 2013, 08:37 AM #11Most Valued Member
It certainly does. Most of us will never know how close we have come to receiving a Darwin Award in our lifetime! I dare say I must have come close, mostly as a kid "experimenting in the backyard" with stuff from Dad's shed! I'm pretty sure I survived a pipe bomb explosion after my homemade solid fuel rocket booster for my lego car went pear shaped....
Yea yea OK maybe not the same scenario, but....
Dangers of Acetylene
By bollie7 in forum METALWORK GENERALReplies: 8Last Post: 9th Dec 2009, 10:16 AM
