Results 106 to 107 of 107
Thread: Vernier FV.3.TO Milling machine
8th Sep 2013, 01:49 AM #106Chief Swarf Maker
- Aug 2013
- 132
Ho-lee-crap that is a big machine! You were brave lifting it all off the base like that. Great work so far!
9th Sep 2013, 11:18 PM #107
Thanks Andrew.
I spent some time running the grinder over the vertical head clamp over the last few days, then finally counterbored the mounting holes. When i had the DH on the mill i also finished the nuts off. Crikey, don't tell me she's nearly done! Not quite yet....
While the head was out of the way i also bored a 25mm end mill holder out to 1.250" for some endmills i got from Brendan. Damn the holder was hard! The weak link in the setup was the BXA toolpost, i ended up removing the height adjustment screw and putting the toolholder right down on the table. The high frequency chatter was unbelievable before i did that....The end mill holder is an Ann Way branded one from Taiwan tools. Real nice quality, best i have seen out of Asia.
Milling machine
By lamestllama in forum METALWORK GENERALReplies: 27Last Post: 21st Jun 2019, 06:02 PM -
Milling machine set ups.
By 4-6-4 in forum METALWORK GENERALReplies: 3Last Post: 1st May 2012, 03:04 PM -
HM 50 milling machine
By woodfast in forum METALWORK GENERALReplies: 3Last Post: 19th Apr 2012, 07:12 PM -
Used Milling Machine
By woodfast in forum METALWORK GENERALReplies: 4Last Post: 15th Apr 2012, 10:07 PM -
Milling machine
By paulj in forum METALWORK GENERALReplies: 1Last Post: 8th Oct 2011, 10:14 PM
