Results 61 to 75 of 107
Thread: Vernier FV.3.TO Milling machine
3rd Feb 2013, 11:58 PM #61Most Valued Member
Going to cost you more in oil than you paid for the mill
Keep it up
StuartLast edited by Stustoys; 4th Feb 2013 at 12:23 PM. Reason: spelling
4th Feb 2013, 10:57 AM #62Golden Member
- May 2003
- 526
Coming along nicely Ewan.
You have done a lot of work on that.Cheers,
Rod
4th Feb 2013, 12:42 PM #63Member
- Apr 2011
- 99
Superb refurb there Ewan, You've done extremely well.
Great video, looks like she runs a treat!. Too many umms in there :P
All the best
Jon
4th Feb 2013, 01:17 PM #64
french
Looking nice Ewan ...... can you do a OCD SCAN OF THE MANUAL ? Mike
4th Feb 2013, 08:52 PM #65Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi Ewan,
Inspiring work...as usual.
You would almost say its being 'bobbed'.
Perhaps you are the new Bob incarnate.
Keep up the great work.
Phil
5th Feb 2013, 09:47 PM #66
Thanks for all the comments.
Maybe i should take out some shares in oil......
Seriously it has cost me about 5 times what the machine cost in transport, bearings, oil, paint, cleaning products, CI for the head clamp etc. Plus tooling of course. Still cheap though....(and 4 weeks of hard work, but thats free right?)
Jon, i would never make a good public speaker......
Mike, tried the OCD, the scan is too poor to get a good read, it ends up in wingdings....i have been translating with google translate on a need to basis, but as the context is rather specialized (not run of the mill conversation) it doesn't always work.
Phil, thanks for the kind words, i don't know about Bobbed. I'm sure Bob would never do some of the dodgy things i have done. Oh, and that nice clean shed you saw a month ago is a right ####fight.
Some more pics while i'm here, in order, the multi plate clutch for the rapid feed, the feed overload clutch (less springs and balls) and the bottom of the saddle in place.1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
10th Feb 2013, 05:33 PM #67
Almost there. I now just need to sort out the coolant pump hoses and i will be able to start on making the uni head clamp. The gearbox and table are on, and everything works. I sorted out the missing switch, once i had my head wrapped around it all became clear, it is pretty simple really. Oddly all the control switching is 24VAC, which made getting new lights a pain, i ended up with 12v globes and a limiting resistor on each one.
10th Feb 2013, 09:57 PM #68.
- 6,459
Ewan,
Sadly some of your narration is drowned out by the motor noise. Very impressive, both Mlle and your achievement in having the machine running in such a short time and appropriately repainted to boot.
Watching the rapids in play might make me squirm under the 13 and wire up its rapid motor. Might.
BT
11th Feb 2013, 06:42 AM #69Philomath in training
Nice work, but I'm still trying to work out whether you paid too much for the mill in the first place...
11th Feb 2013, 10:12 AM #70
What else does it do
Does that machine wash the dishes too it seems to do just about everything else ....Mike
11th Feb 2013, 11:03 PM #71
Michael, that purchase price sure was a killer.....
Mike, i don't know about washing dishes but i'm sure it could turn them to grog pretty well.
I started on the head clamp last night and today. I'm already cursing i didn't buy a bigger saw blade, 6" really isn't big enough when your cutting up 120 dia bar. One thing i have found out is my 1" arbor is bent oh well, comes back to that purchase price i guess.
Pics of cutting and slab milling the bar. The last pic shows a full 2" deep cut with the saw, it is only 1/16 thick, 44 tooth. Even with the bent arbor Mlle barely sounded like she put any effort in....(although i had one problem but i'll start a new post)
IMAG1585 (Large).jpgIMAG1586 (Large).jpgIMAG1592 (Large).jpgIMAG1598 (Large).jpg1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
16th Feb 2013, 08:22 PM #72
More progress on the head clamp today. They say 4E does not have any hard spots but i seem to have found some. In the first pic you can see some shiny spots where it is clearly harder. The saw worked fine with no key, I just had keys in the collars to either side of it, thanks Michael.
I also put up 2 vids, the first may make anyone with a lack of Z cry......(sorry BT) The second is a 20mm HSSM2AL Rippa cutter from CTC doing its thing......however it got a bit hot and a couple of cuts later i melted the end 2 teeth and snapped it off. I know that generally CI is machined dry but i wonder if some coolant wouldn't have been a good idea to keep the cutter cooler? I was running it at 490 rpm and 9" a min feed (i think?) This is under the "recommended" feed and speed for hogging CI as per the info i have collected.
16th Feb 2013, 08:36 PM #73Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Great stuff Ewan, but then....Bugga.
It certainly ripped it out while it was working
16th Feb 2013, 08:42 PM #74
Thanks Phil,
I didn't mention above, but i tried one of your suggestions and started by hand feeding (hence the cut is already started in the vid) and then comparing the feed rate to my rate, and it was about the same, so? I guess now i have 6hp to play with the mill won't really tell me when enough is enough.....i shudder to think how the HM50 would have coped with such a cut, damn she is rigid!1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
16th Feb 2013, 09:32 PM #75.
- 6,459
Bloody Show Off!
I have machined a fair bit of 4E and it sometimes has hard spots. Hard enough for sparks to fly. The blokes out at Bohler have said it is not uncommmon. I think Bohler sells Flocast cast bar. Cast Iron Bar,Continuous Cast Iron Solid Bar,Ductile Iron,Grey Iron Casting supplier
My Hercus mill arbor is keyless and that's never been a problem. But 1/2 a horsepower aint 6.
B drying his eyes T
Milling machine
By lamestllama in forum METALWORK GENERALReplies: 27Last Post: 21st Jun 2019, 06:02 PM -
Milling machine set ups.
By 4-6-4 in forum METALWORK GENERALReplies: 3Last Post: 1st May 2012, 03:04 PM -
HM 50 milling machine
By woodfast in forum METALWORK GENERALReplies: 3Last Post: 19th Apr 2012, 07:12 PM -
Used Milling Machine
By woodfast in forum METALWORK GENERALReplies: 4Last Post: 15th Apr 2012, 10:07 PM -
Milling machine
By paulj in forum METALWORK GENERALReplies: 1Last Post: 8th Oct 2011, 10:14 PM
