Results 31 to 45 of 107
Thread: Vernier FV.3.TO Milling machine
7th Jan 2013, 12:30 AM #31.
- 6,459
Nice explicit drawing Ew. 4E is supposedly the easiest cast iron to machine. Should do the job. Bohler sell Flocast products.
Cast Iron Bar,Continuous Cast Iron Solid Bar,Ductile Iron,Grey Iron Casting supplier
What do you reckon you'll make the nuts from? I used 1045 for that little tool post on the ball turner. Certainly a lot easier to machine than 4140. A good chance it would do for the nuts.
BT
8th Jan 2013, 12:28 AM #32Golden Member
- Mar 2009
- 54
- 825
G'day Ewan,
Regarding translating your manual, Acrobat (the full one not the reader) actually has a fairly good OCR built in.
If you want to email me the pdf copy of your manual I can run it through the OCR and then you can use google translate, babelfish or something similar.
Greg.
10th Jan 2013, 01:51 AM #33
Mlle has landed!
Well, it took some doing be we manged to muscle all 2.5 ton of her into the corner of the shed. She sure is large, the same sort of large that Freddie and Blondie are, she says, don't f### with me......
Some good news and some bad....
The good- the uni head now spins free, main gearbox is in great nick, the oil pump is working, electrics look fine.
The bad- water has gotten into the feed box and clutches, there is some rusting although most of it seems to just be growing on the steel, not actually eating into it, 1" arbor is rusted, may be ok, may not, can't seem to unlock the table swivel, and the y axis is still stuck in gear....probably rusted.
Pics, in order:
On truck, ready to be unloaded,
In place,
Yes the table is supposed to go that far over!,
The X ways, the "galley" in the back is for coolant, it drains from the center of the table
Introductions....
Couple of the gearbox, the pump works just turning the belts by hand,
Electrics, all ok, just a bit of surface rust on the frames,
Motor, drive belts and coolant pump,
3 pics of the feed boxes and the rust,
The cap (?) is driven by chain, not rack and pinion,
The angle graduation on the uni head have vernier scales1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
10th Jan 2013, 08:00 AM #34Senior Member
- Dec 2011
- South East Queensland, Australia
- 355
Late night eh Ueee, I noticed your post time. The things that can keep one up late at night.
Bit of work ahead but good to see you got it in place ok.
Cheers.If I'm not right, then I'm wrong, I'll just go bend some more bananas.
10th Jan 2013, 08:29 AM #35.
- 6,459
The Parisienne looks even better than I imagined Ew. The paintwork appears to be in reasonable nick too. (Fingers crossed you don't repaint her bleu de France.)
Thank you for the photos.
Bob.
10th Jan 2013, 10:48 AM #36
Heavy
Hi Ewan ..
The main gearbox is more important anyway ,it will be a while until you strip it down, so I would apply something onto the rusty feed gears to stop any more rusting action eating into the metal gears , they will clean up OK
10th Jan 2013, 11:32 AM #37Pink 10EE owner
- 6,218
I see yours has the same silly idea of the coolant flowing through the middle of one of the ways... My Jafo has the same system that was full of crap and had blocked off the outlet hole making coolant flow all over the ways creating a corrosion problem....
Also it had damaged table feed gears due to coolant ingress... It gets into the system through the table swivel as the feed shaft has to come up from the centre of the saddle requiring gaskets and seals which never get checked or replaced over the long period of time since it was new....Gold, the colour of choice for the discerning person.
10th Jan 2013, 03:02 PM #38Philomath in training
Surely the most appropriate colour to paint a French mlle. mill would be (moulon) rouge?
10th Jan 2013, 03:17 PM #39
Oui, oui. C'est vrai.
It's all part of the service here at The House of Pain™
10th Jan 2013, 04:21 PM #40.
- 6,459
10th Jan 2013, 05:29 PM #41Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Sackry Blue!
10th Jan 2013, 05:38 PM #42Pink 10EE owner
- 6,218
I say if you are going to live in this country you should speak the language of this country...
damn, struth, cobber, strike me roan...Gold, the colour of choice for the discerning person.
10th Jan 2013, 06:36 PM #43It's all part of the service here at The House of Pain™
10th Jan 2013, 08:52 PM #44
Oops, someone mustn't of told me or Mlle that.....
Firstly yes R.C. it has that system. bit it seems to not have overflowed, the oil bath for the X travel gears etc had no water in it, and not rust. I could see it getting blocked though, there is no filter and no place for a filter on the table, so the trough is full of shavings. The feed boxes i would say got water through the cover gaskets.
I have worked out what the 4 levers are, they drive a worm each, that in turn tightens or loosens a nut to clamp the swiveling table in place.
After cleaning all the muck off the table it has been removed, exposing the adjustable leadscrew nuts (one fixed and one adjustable) and the forward/reverse x table travel. I then took the top half of the saddle off, revealing a large O ring to seal the x feed oil bath. I also took the front of the uni head off, revealing the curved bevel gears (i'm sure there is a proper name for them) and another oil bath.1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
10th Jan 2013, 09:02 PM #45
[QUOTE=I also took the front of the uni head off, revealing the curved bevel gears (i'm sure there is a proper name for them) and another oil bath.[/QUOTE]
zyklo-palloid gears is a trade mark. Otherwise known as spiral bevel gearsIt's all part of the service here at The House of Pain™
Milling machine
By lamestllama in forum METALWORK GENERALReplies: 27Last Post: 21st Jun 2019, 06:02 PM -
Milling machine set ups.
By 4-6-4 in forum METALWORK GENERALReplies: 3Last Post: 1st May 2012, 03:04 PM -
HM 50 milling machine
By woodfast in forum METALWORK GENERALReplies: 3Last Post: 19th Apr 2012, 07:12 PM -
Used Milling Machine
By woodfast in forum METALWORK GENERALReplies: 4Last Post: 15th Apr 2012, 10:07 PM -
Milling machine
By paulj in forum METALWORK GENERALReplies: 1Last Post: 8th Oct 2011, 10:14 PM
